Old 09-05-2013, 12:01 PM
cfd2bc's Avatar
cfd2bc cfd2bc is offline
Default 66 3 speed and 4 speed questions
Hello all...I have a 66 Lemans with a Pont 350 and TH350 with 3.36 rear. I want to put a 4 speed in mine.
I bought another 66 with a factory 3 speed, 326 so all of the parts are there to convert mine to a manual. The questions I have are:
will the flywheel transfer to mine?
same bellhousing for a 3 speed and 4 speed?
will I have to change my rear end ratio?
Thanks!
Jeff
kcmusclecars.com
Old 09-05-2013, 02:06 PM
428goat 428goat is offline
I would think you would be good to go.
Old 09-05-2013, 02:37 PM
Singleton Singleton is offline
The Bellhousing should have holes for both the 3 and 4 speed. The flywheel register hole for the crank may not work, there are two different sizes.
Which 3 speed trans is it? The HD dearborn, (ford), or the standard light duty 3 speed?
If its the Dearborn, the output splines are different than a muncie 4 speed. Would have to change the slip yoke if thats the case.
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 09-05-2013, 03:08 PM
Andre's Avatar
Andre Andre is offline
With the 4 speed you will continue to use your driveshaft and and yoke that you have on the TH350, and it will NOT require any modification. The crossmember wont move, and you won't have to fool with the parking brake cables etc.
Old 09-05-2013, 03:41 PM
geeteeohguy's Avatar
Very easy conversion. Your rear end ratio is perfect for a stickshift car. 3 speeds, 4 speeds, and the TH350 all have the same 1:1 final drive ratio, so the only change you'll notice is slight lower rpm's on the highway due to no torque converter slippage.
Jeff
Old 09-05-2013, 04:58 PM
Flywheel register will not be an issue, it will swap.
Old 09-05-2013, 06:33 PM
cfd2bc's Avatar
Thanks so much for all of the replies! Sounds like I'm good to go.
kcmusclecars.com
Old 09-05-2013, 06:56 PM
Just make sure the 350 crankshaft is drilled for a pilot bearing, some auto trans crankshafts won't accomodate one.
Old 09-07-2013, 07:07 PM
cfd2bc's Avatar
I should be able to tell that by the block code correct? "W" is manual? "Y" is auto?
kcmusclecars.com
Old 09-07-2013, 07:14 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
I don't think think this is true. I have a y coded block that had a pilot bushing
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 09-07-2013, 08:26 PM
cfd2bc's Avatar
Ah ok. I guess I'll have to just pull her apart and take a look. Thanks.
kcmusclecars.com
