This is from a 67 OHC I picked up this spring
Motor was removed from a 67 Lemans in favor of a more "popular" 400 V8 Sat outside for 15+ years, but the owner did cover the carb with an old spackle bucket! ![]() The motor was obviously stuck from sitting outside all those years, but I was mainly interested in the power steering dual groove pulley & pump, the dual groove alternator, the water pump pulley and the A/C compressor & brackets. ![]() I originally thought it was just an aftermarket flex fan, but it seemed strange that everything else was original. I also have the more traditional 7 blade fan.
67 Lemans OHC 6 Sprint Clone T-5 5 speed convertible |
might be the 68 A/C fan
got any #s on it?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
The motor is stored at work; I'll check and post the numbers tomorrow.
The fan did have a spacer installed as per Jeff's parts diagram which originally made me think it was an add on. I thought the spacer would move the fan too close to the radiator. The car was definitely a 67. I was shown photos of the completed car when it was repainted. I would guess that the OHC/fan assembly could have been swapped out earlier in it's life, but it sure looked original to me. Ron
67 Lemans OHC 6 Sprint Clone T-5 5 speed convertible Last edited by OHCSprint67; 09-15-2013 at 09:12 AM. |
Without question it is a 67-69 Firebird fan and spacer.
Remembering the longer engine bay/nose of the Firebirds is why they used/needed a spacer.
looks a lot like a ram air III or IV fan...dont it...
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." ![]() |
actually it was very close Mark
Ive got a used one of one an NOS of the other when I can get to it Ill compare
There was a difference in diameter
There are 2 sets of numbers on the backside of one of the blades
The top # is stamped SC 9135697 The bottom # is stamped 9788982 The front part is simply stamped FRONT! ![]() I was told this was from a 67 Lemans, but with the aluminum spacer, it doesn't look like it would fit without hitting the radiator. Any ideas as to year or model? Ron
It's listed on the first generation Firebird site as:
9788982 7 blade, 18" diameter Power-Flex 1967-9 L6 with A.C. or H.D. ![]()
Not a 67 A body thats for sure
those were fixed 7 blade with A/C and not enough room for the Firebird only flex fan and or a spacer(ask me how I know)
Will the 7 blade fan used on A body OHC work and cool ok on a F body with ac? I have a seven blade off a 67 A body OHC with air and was planning on using it on my firebird one day, but now see it was a different fan with different spacing from radiator.
I have the fan & spacer for the Firebird, but I own a Lemans
You have the fan for the Lemans, but own a Firebird. Looks like the making of a parts swap! ![]() I have the fan, spacer and the 4 original bolts. pm me if interested Ron
![]() Quote:
both are hard to find and wont work right when mixed up
Looks like the 428 HO fan(s) i had come across in the 80's.
