reusing Cometic gaskets
I have a set of Cometic gasket I ran on a motor that had around 80 passes before the block cracked # 4 main saddle. Old motor had cast iron heads new motor will have Edelbrocks.
The Following User Says Thank You to 428ratkiller For This Useful Post: | ||
i reuse mine and have three times before seeing signs of leaking. clean them and use copper coat on them with no problems.
Dumb question/ dumb move here: I installed a brand new set of Cometics that I coated with copper coat before I installed and torqued them down on my new build when I discovered that the E heads pushrod holes were not clearanced. So when I finally pull the heads back off to fix that issue, what do I need to do to them before reinstalling them? Just coat them again or thoroughly clean the gaskets of the old coating then reinstall. I know the answer but I'm curious what other do when the re-use them. The motor has never been fired yet.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
Calvin Hill Hill Performance 708-250-7420 |
If you call cometic they will tell you not to coat them. I have coated them too. but I tried not coating them and I still have the same one on a year later and I run a turbo with 25psi.. just passing on what I was told....
My Half AN Injun..... |
Never found any gain coating them - they're coated when they arrive. If reused however I'd coat them as the original coating is pretty sketchy after removal - I've used copper coat and red spray tack with equal success. Brakekleen will remove the original coating as well if that's a goal.
What's key is a smooth/mirror finish on the heads and block - no cutter marks.
The secret to happiness is not getting what you want but rather, wanting what you have. |
I was told to clean them off and spray them with SILVER spray paint. It worked just fine for me.
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
I was told to lightly coat them with Ultra gray . The machine shop that has been building sprint car motors for the last 30 years wont assemble without it . I have done this the last 2 time with no problems .
I've reused them but only with the same heads on the same block and had no issues. Changing heads or block with used gaskets may work but something I wouldn't care to try.
Monty Frerichs B&M Machine Box Elder SD |
I have reused them with out coating them and never had a problem... If it makes you feel better then just coat them. Either way you will be fine...
Any body reused Cometics going from E heads to iron?
Is there a way to tell how thick the gasket is? They are new to me. Came of a motor that had never been fired. Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft |
I've used and re-used Cometics switching blocks & heads and never coated them. Never had a problem either. Usually these are anywhere from 11:1 - 13:1 compression, n/a motors.
http://www.youtube.com/watch?v=t9eWgLd0q-U |
The Following User Says Thank You to Hillard For This Useful Post: | ||
