Old 10-02-2013, 09:53 AM
GtoBrian's Avatar
GtoBrian GtoBrian is offline
Default 1970 M-21 Muncie WANTED
Looking to convert my 70 455HO GTO from an auto to stick, looking for a good used or rebuilt M-21 with the large output shaft,and correct shifter also, also looking for a good floor shift column as mine is on the column, thanks.
1969 Judge, Matador Red, Black, RAIII 4Spd, Owned 33years
1974 LeMans GT Honduras Maroon, 3 speed stick 350 2brl.
1963 Catalina 389 Black with Burgandy Ventura interior SOLD
1970 GTO Pepper Green 400 YS auto Factory A/C 56K orig miles
Old 10-03-2013, 08:15 AM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
Question Floor shift column
Fixed or tilt column? I should have both. Thanks, Bob.
Old 10-03-2013, 08:50 AM
GtoBrian's Avatar
Looking for a fixed column, preferably black, thanks.
Old 10-03-2013, 09:48 AM
Smile Fixed floor shift column
I have two in black; both will need re-finished. I also have one '69 GTO in Garnet. E-mail [email protected] for pics, etc. Thanks, Bob.
Old 10-13-2013, 07:01 PM
carsmymistress carsmymistress is offline
Default M21 Available
I have an M21 from my 69 GTO that I have decided not to keep any longer. I removed it 5 years ago to install a TKO and with all of the other mods there is really no reason to attempt to convert it back to original. The trans shifted perfect when removed and has been in ac storage since.
If you need more parts, I have the trans, bell housing, clutch fork, drive shaft, correct shifter mount, shifter and rods, and possibly the zbar if you need them. If you have interest, I can round up photos pretty quick on the parts.
Thanks,
Old 10-14-2013, 09:28 AM
I never did hear from you regarding the columns that I have.
Old 10-14-2013, 10:47 AM
GtoBrian's Avatar
Holding off on that for right now, will let you know if im still interested, and thank you.
