Old 10-16-2013, 12:30 PM
1972jim 1972jim is offline
Default Need 1963 lemans clutch and brake pedal set up.
Just the pedals/dash hardware to convert auto to stick.
Old 10-19-2013, 06:22 PM
Doug Doug is offline
I lost track of this post and had to ask in 61-63 Tempest & Lemans forum where to find it. c5farmer told me where to find it again.
When I first read your post I had forgotten that I had some of this stuff. I stumbled on it under a bench today. I have the pedals and the "hoop" bracket that ties them together.
I don't have the under-dash piece that the pedals mount to. The only difference between that piece itself in an automatic car and a manual car is that the manual one has a small piece of angle iron mounted on the side of it. That angle piece has a small flat piece of rubber on it. The purpose of that "angle" is it serves as a "rebound stop" for the clutch pedal when it is released. You can use your auto under-dash piece and bolt a small piece of angle iron on it and it will serve exactly the same as a manual setup does.
Do you have ANY of the clutch pedal setup? Under hood pieces? Bolt-to-motor bolt?
Old 10-19-2013, 06:34 PM
Default Clutch and brake pedals
I don't have any pieces under the hood or engine bolt. I'm going to run a hydraulic clutch set up.
Old 10-19-2013, 10:19 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
You might use one that the master cylinder mounts under the dash ... there is almost no room to mount it on the firewall! John
Old 10-20-2013, 06:26 PM
Cool pedals?
Here is a pic of the pieces I have. You can have them (less the pads which I need for my car) for $10+shipping.
Name:	017 (600x450).jpg
Old 10-31-2013, 10:33 AM
Send me your address and the total and ill send you out a check. Thanks! Jim
Old 10-31-2013, 09:43 PM
Default pedals?
Pedals sold to another member a few days ago.
