Window molding pins
Anyone have time to measure the rear window molding pins I need to know where they start from the corners have a few originals left but none close to the corners trying to get the glass in this week.
Thanks |
Hey 1966geeto,I just measured the pins on my Tempest 4 door. I believe it would be much the same. the measurments are as such. across the bottom I measured 3"from the corner, going from bottom to top, I measured 31/2", top of side trim measured 4", going from side trim across top I measured 31/2". Hope this helps, Rick
I just painted a 66 a couple weeks ago. I can grab you a couple pics too in the morning.
Thanks, Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
