THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
welding with brake clean
A friend of mine just told me of a fellow he knows was welding some parts they cleaned with brake clean. He is in a coma and really messed up! Not sure he is going to pull through.
I had never heard of the danger before and wanted to get the word out to others.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Found this.
http://www.brewracingframes.com/id75.htm
That story has been posted here before about the dangers of certain kinds of spray cleaners. Also,,, Dont use it as a carb cleaner on a running engine!!!! Almost took me out one night!!
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
The Following User Says Thank You to mechanickeith For This Useful Post: | ||
I like brake clean but guess I will be more careful.
I dont think I will be buying brake clean anytime soon....Thanks for posting
Good information! I'm going to forward that link to friends.
And for safety, always wear an approved respirator when welding, like a 3M 07184 P100. |
very bad this has been going around for a while
no cleaners for welding !! hope your friend comes out ok
________________________________________ 65 GTO owner since 84 original ca car |
That is some bad stuff.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
Good to post to know.
Isn't there also the same effect to welding galvanized metal? |
I had never heard this before either until watching an episode of Horsepower the other day. They mentioned it in conjunction with cleaning and storage oil off of steel plates before welding. They said to always use acetone to clean any parts before welding. I hope your friend pulls through ...
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
Thanks for posting. Often we give no thought and just delve right into a job.
My money talks to me-it usually says goodbye! |
WOW. I use brake cleaner all the time, but not around flame. THANK YOU for the heads-up!!! This should probably be a 'sticky'.
Jeff |
Wow...I had no idea. Thank you for the heads up!
Greg Reid Palmetto, Georgia |
Not all brake kleens are poisonous. Read the lables people!! The bad ones produce Phozgene gass. Ver potent & deadly nerv gas!!
Green brake clean is environmentally safe (hence green) but is FLAMMABLE.
Red brake clean is not environmentally safe (hence red) but is NOT FLAMMABLE. I train in the transportation of these kinds of chemicals. Red has the old "trichloroethane) in it and the green does not.
JLP |
Holy Smokes. thanks for the remind. Had a fella welding aluminum for me: good thing these parts were laser-cut. I'm fixing to ask how the psrts got cleaned after cutting. Have more work for him.
Yeah, gotta watch anything that is chlorinated or contains chemicals that will polymerize or react in the presence of heat. Many shop chemicals that are fairly safe at room temp will become crazy poisonous when heated. Chlorinated brake cleaner, paint stripper with methylene chloride, urethane paints all become VERY toxic when burned or heated beyond their intended use temperatures.
Come on... it's Brake Clean, not a degreaser or starting fluid. And not intended for use on anything other than cleaning brake parts.
Brake cleaner
Works great for starting diesel engines rather than using ether. Ed
Do shops (that train) include this hazard in employees shop training..specifically? Actually make it a topic of discussion with the brands being mentioned? |
