Old 11-09-2013, 07:23 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Cylinder head stand dimensions
Does anybody have a set of head stands that you could measure so I can make a set?
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 11-10-2013, 09:47 AM
steve25 steve25 is offline
Make them for your needs, doing porting work compared to say cutting valve guide tops or dressing the upper Intake push rod holes will make for a need for different type stands.
Old 11-10-2013, 10:23 AM
67gtospud's Avatar
I'm only going to be doing basic work such as removing the valve springs, changing rocker studs, ect.
Old 11-10-2013, 11:00 AM
Like this style?
2" X 8" X 1/4" steel plate
9/16" diameter round steel stock, 6-inches long
times 2
Or this style:
Wouldn't be that hard either probably.
Old 11-10-2013, 11:14 AM
67gtospud's Avatar
Like this style?
times 2
Or this style:
Yup the first one, thank you, I couldn't see paying $50 for a pair when I could make them for $5-10
Old 11-10-2013, 12:42 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I have both and use both at work for different jobs. One set works better for some things and the other set works better for others. Just depends on whats being done.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 11-10-2013, 02:35 PM
67gtospud's Avatar
So the round shaft is just 9/16" tapered down?
Old 11-10-2013, 02:45 PM
Yes.
The holes in head are for 1/2" bolts.
Probably anything bigger would work, as long as it tapered down so they would go in the head bolt holes.
Old 11-10-2013, 03:08 PM
67gtospud's Avatar
Thanks for the replies!
Old 11-10-2013, 03:35 PM
Old 11-10-2013, 10:59 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I have one from Jim Hand. No idea if he makes them any more.
http://www.pontiacpower.org/
Old 11-12-2013, 04:37 AM
Bob Eiler's Avatar
Bob Eiler Bob Eiler is offline
I fabricated these stands for Pontiac heads. If you can weld, not very hard to make
ID:	342819   Click image for larger version
ID:	342820   Click image for larger version
There is no such thing as too much cam, just not enough engine.
1966 GTO - 11.31@119 (3478 lbs) in 1979
1967 Firebird - 9.73@138 (2940 lbs) in 1986
400 cu in / 295-298 cfm RAIV / Lunati Cam 278/283 - .704 lift/5.13 gears
Old 11-13-2013, 01:25 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Gittr dun!
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
