Old 12-14-2013, 07:20 AM
Andy65GTO's Avatar
Andy65GTO Andy65GTO is offline
Default Under Dash Gauges on 65 GTO
I'm in two minds whether to leave my interior all original or sacrifice it by installing triple chrome VDO gauges under the dash. What do you guys think they look like, do they kill the look of the original interior? Unfortunately I don't have the rally gauge cluster and don't want to go to the trouble and expense of taking the dash apart so im in need of the oil, water and volt readings.
Andy
Old 12-14-2013, 07:35 AM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Put them in the glove box. If you're not sure about how you like them.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 12-14-2013, 09:08 AM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
I like the look of having the triple chrome gauges. I have autogauge from Summit. Even with a console they look good if tastefully done. You can put them on a hinge and flip them up and back to hide during shows if desired.
Here's a pic of mine:
http://s1003.photobucket.com/user/jr...ml?sort=3&o=16
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 12-14-2013, 11:23 AM
rohrt rohrt is offline
Anyone remember the classicalpontiac site. In the restoration area they talk about mounting the gauges on hinges so they can be swung out of site. I would like to do this my self.
I would think you would need all electrical gauges vs mechanical in order to do that.
Old 12-14-2013, 12:39 PM
geeteeohguy's Avatar
Andy, my own '65 had a trio of SW gauges mounted under the dash when I got the car in 1982. Because I had a rally cluster, they were redundant, but these gauge clusters were very popular back in the day. I removed mine about 4 years ago and re-connected the oil and water gauges in order to 'clean up' my interior. That said, an aftermarket gauge trio is a perfectly acceptable modification, 'period correct', and is easily 'undone' if you don't like it. The one or two small screw holes are out of sight under the dash, and can even be filled and repainted if you are a fanatic. (I left mine there, as the dash is original paint and I didn't want to change anything). I say go for it if you want.
Jeff
Old 12-14-2013, 12:57 PM
65blackplate's Avatar
65blackplate 65blackplate is offline
I am in the same boat as the OP I need to find a SW oil pres and temp guage I like the period correct guages
________________________________________
65 GTO
owner since 84
original ca car
Old 12-14-2013, 04:28 PM
Old Man Taylor's Avatar
I had Stewart Warner gauges until my old age. I took them off and installed the large face Autogage setup.
Name:	GTO S-W Gauges.jpg
ID:	346473   Click image for larger version
Name:	DSCN7142.jpg small.jpg
Old 12-14-2013, 05:15 PM
chinquapalian chinquapalian is offline
better than idiot lights 2cents
Old 12-14-2013, 06:41 PM
Tom Vaught's Avatar
Boost Engineer
I ran SW Gages from "Day One" when I received the car from my uncle.
I also still have those gages but changed the plastic tubing to small diameter stainless tubing after having a oil leak on the Oil Pressure gage.
Eyes are not that great anymore but I can still read the large face gages fine so that is what I have now (and a oil pressure warning light with a 15 psi trigger. That has saved be when I had a oil filter o-ring gasket leak on me. It also sounds a audible alarm "Beep Beep Beep" in the car.
Yes, I like the look of the old gages under the dash on a 64-65 type vehicle.
Tom Vaught
Old 12-14-2013, 07:04 PM
The Champ's Avatar
I put Stewart Warner Green Line gauges in mine (just oil and temp). Went with the 2 5/8 inch size for easier reading.
Very happy and I think like many others here feel it's period correct.
Old 12-14-2013, 07:39 PM
Champ, your SW gauge looks a lot like the 40 year old SW stuff I removed from my '65. Definitely 'period correct' IMO.
Jeff
Old 12-14-2013, 09:51 PM
Andy65GTO's Avatar
Thanks for the feedback. The hinged idea got me thinking instead of hinges, setting up a slide type set up on 2 tracks.This way i can slide them back towards the firewall when not in use mostly out of site. I think that will work even with mechanical gauges.
Old 12-14-2013, 10:23 PM
Chris65LeMans's Avatar
This is my set-up. They are SW gauges with a mechanical oil pressure one.
Old 12-14-2013, 11:53 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Went to autometer on my 64, under dash gauges. But only used 2, oil pressure and temp, left the idiot light for charging system. Look good well to me anyhow.
64 Lemans hardtop
4spd, buckets
Old 12-15-2013, 12:59 AM
Not a '65...this is my '68 but I decided to try to make mine integrate with the existing dash by painting the housing the interior color. You can get the housings that slant either right or left so you can get the left slant and invert it.
Old 12-15-2013, 03:36 PM
Tom Vaught's Avatar
Boost Engineer
Tom Vaught
Time for a new keyboard.
Tom Vaught
Old 12-16-2013, 09:56 AM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
I think they would look awesome and be totally period correct.
These have been located here a few months shy of 50 years.
K
'63 LeMans Convertible
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 12-16-2013, 10:41 AM
3 Deuce 64's Avatar
3 Deuce 64 3 Deuce 64 is offline
Send a message via AIM to 3 Deuce 64
The gages that I have in my 64 tri power car are not SW but lookalikes. They were put in a 64 hard top new at the Pontiac garage . I bought the car from the original owners . I snagged them out of that car and they've been in the convertible ever since then well over 30 years now .
Name:	1964 gto interior.jpg
ID:	346666   Click image for larger version
Name:	64 period correct gages.jpg
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln
"A free people ought not only to be armed and disciplined, but
they should have sufficient arms and ammunition to maintain a
status of independence from any who might attempt to abuse them,
which would include their own government." — George Washington
Old 12-18-2013, 11:44 AM
CrappieCat CrappieCat is offline
I have found this one in the barn,
I forgot I had it til I saw this post.
Saved from hibernation since 1979.
Old 12-18-2013, 08:54 PM
Andy65GTO's Avatar
Very cool find!
