I have a thread going in the Street section about aftermarket gauges. I'd like to mount aftermarket Oil Pressure and Water Temp. gauges in my 71' GTO. The car only came with idiot lights,and I don't want to convert to factory gauges to keep the car original as it is pretty stock looking/original still,and it would be easy to remove the aftermarket gauges if I ever sell the car.
I thought about mounting them on a swivel mount on the bottom of the dash,and I could angle them up towards me for easy reading. After going out and looking at my dash it runs quite a ways under and out of sight towards the firewall,so I don't think this idea will work. So how do you guys with stock interiors mount aftermarket gauges without cutting into things? I'd also like to mount them as hidden as possible if I can,to keep it looking original.
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
I run a two pod gauge under the dash using one of the screws holding the bottom of the ashtray bracket in and maybe one other hole drilled up underneath to hold it from twisting.
Car's in the storage tent buried in snow right now, this is the only pic I could find in the archives, not a good shot, but you can see them if you squint! |
| The Following User Says Thank You to gto4evr For This Useful Post: | ||
I remember seeing someone use a couple of clips off or tape measures on the gauge housing so they didn't have to drill the dash - seemed like a good solution. I think the post was either here or on CP quite some time ago-might find it with some searching.
| The Following User Says Thank You to bdk1976 For This Useful Post: | ||
Here's what I did when I wanted to add extra gauges into my dash facia.....
![]() I cheated and bought a carbon fibre one from Thunder Road. ![]() And I installed SoCal Gauges. ![]() So this is what she looks like at the moment. I installed this dash in Janaury last year and so far haven't had a chance to drive her yet to tie in the speedo, but all the rest of the gauges work real fine. ![]() And this is her.....
'66 Valiant Regal 225 '72 Lemans Station Wagon T-41, 455 '76 Trans Am 455 '77 Ford F-100 4WD 351 '78 Ford F-100 2WD 302 '79 Firebird Black 301 '79 Z28 350 '79 Trans Am 403 numbers matching '04 Ford Falcon XR8 5.4 ltr. and no wife.........Yipppeeeeeee |
falcon, that's a pretty radical change from stock! Looks cool though. I notice your car's got AC but that dash insert blocks off the upper vent with that 5 light bar. What are the lights for?
Falcon,yes that looks great,but I'm looking to not stray from original as much as possible.
I have a 2 pod gauge mounted pretty much the same as gto4evr. That lower metal dash piece comes off, so if you modify it it's easy to replace with another one if you want to remove the gauges later.
| The Following User Says Thank You to pggto For This Useful Post: | ||
Dennis, I love what I see of that car!
Mitch Kunath |
The lights are left indicator, idiot light brake fail, high beam, idiot light E-brake and right indicator. The little chrome box with the hole in it is for a right hand side remote mirror.
http://www.jegs.com/p/Auto-Meter/Aut...34739/10002/-1
yeah, another vote for oil and temp only. Also, I ran the temp off the other side of the intake and T'd off the oil sending unit so both my idiot lights and the gauges work. A gauge is fine, but it doesn't draw your attention to the problem as fast as a glowing red light of death in your dash does! |
I mount mine in the cut out for the ashtray. Mounting them like this eliminates the ashtray, but it was the only place I could find where they'd be visible and I wouldn't have to make any holes in the dash.
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
| The Following User Says Thank You to goatless For This Useful Post: | ||
One of my 'when I have time' projects is to take an extra ash tray and modify it so the gauges fit inside/attach to it with the wires connected with Weather Pack connectors. If I want to remove the gauges for a show I can remove and unplug them, and then install the 'good' ash tray.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same. -RONALD REAGAN 462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg |
I used earth magnets and extreme velcro from Lowes, worked great plus easy to remove.
| The Following User Says Thank You to rwarnerjr For This Useful Post: | ||
I mounted mine on the plastic A/C duct under the dash. I did put two small screw holes in it but it's just the plastic duct and easily replaceable if need be.
Also I taped a piece of sandpaper, grit out, to the area in which I wanted to mount the pod. By doing this, I was able to carefully rub the pod back and forth across the sandpaper until it conformed to the shape of the duct. Not a great pic since it was before I mounted it back into the car but you get the idea. Also, I painted the pod the color of the dash. I need to redo the 'chrome'... It's just silver paint.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 12-19-2013 at 05:32 PM. |
| The Following User Says Thank You to Greg Reid For This Useful Post: | ||
Great idea!
Greg Reid Palmetto, Georgia |
On my 66 i just got another dash pad core and made one with gauges, used quick disconnects so i can swap back to stock dash pad if i chose.
1966 Tempest Custom, 473, dual quads, 3:55 12 bolt http://s1098.photobucket.com/albums/...966%20Tempest/ |
Greg, where'd you get those pod cases? I like them! Mine's the standard cheap metal L bracket leaving the gauges exposed from the sides, yours looks way more finished with the covers like that. |
i used 2 small old sun gauges...gutted my ashtray...when i open the ashtray door..i have gauges..when i dont, i close the door. in a 68 tempest
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
| The Following User Says Thank You to marxjunk For This Useful Post: | ||
