Old 12-15-2013, 03:46 PM
propuckstopper propuckstopper is offline
Default 1965 GTO Rear End Identification
Hi everyone. I have just found what I think might be a 1965 GTO rear end, but the seller is located far away and all I have to go on is a picture.
There are no numbers anywhere on the rear end, according to the seller. The only thing I can confirm is that the shock mounts are "1 finger width" from the backing plates.
My question is: when looking at this picture, is there any way to determine whether or not this rear is from a 1965 GTO? Does anything "stick out" to you confirming yes or no?
Here's the pic:
http://imageshack.com/a/img824/5872/6sb2.jpg
Thanks!
Old 12-15-2013, 05:06 PM
Appears to be a small upper control arm bushing '64 A-body rearend. Either a '64 Pontiac 8.2 10 bolt, or a '64 Buick 8.2 out of a '64 Olds F-85 or Buick Skylark.
The limited picture shows only one access hole in the axle flange, which denotes Pontiac 8.2, but this axle & the early Buick 8.2 axle will directly interchange in each other housing. The picture also does not give a full view of the axle flange, there may be 3 holes which in this length axle would designate the early Buick 8.2 10 bolt.
If you can a have the seller clean up the cast iron webbing of the center section where the center section spans to the axle tubes, there should be a casting number, starts with a 97xxxx. That is an early Pontiac 8.2 rear casting number. If there is no casting number there, have him ck the area directly behind the pinion flange.
Old 12-16-2013, 01:30 AM
Peje Peje is offline
For 1965: A two letter code is stamped on the back passenger side of the axle tube.It identifies the axle ratio and if the axle is equipped with the Safe T-Track option.
PS: On a rusty axle it is very hard to see so you have to clean it down to pure metal.
Old 12-16-2013, 12:49 PM
Default Thanks!
Hi guys. Thanks for the help. I had the seller measure the upper rear bushing shells and they measured about 1.375". This points to an earlier 1964-style rear end as Ol' Pinion Head suggests. Needless to say, this isn't the rear end I am after.
Still looking for a correct 1965 GTO rear end, ideally YH stamped (355). I have every part to rebuild it including new R&P, Eaton Posi, and bearings. Even a good housing would work in my case, although I would like to get backing plates and axles if possible.
I guess these things are harder to find than I thought.
Thanks again!
Old 12-17-2013, 11:48 AM
Default Found Another One. Opinions?
OK. I have a line on another rear end, this one also is "supposed" to be a 308 posi original to a 1965 GTO. As you will see from the pictures below, it carries casting number 9777142. I always thought that all '65 rears used 9779822?
Anyway, the pictures aren't great, but does 'ol Pinion Head or anyone else have an opinion as to the possible authenticity on this rear?
Thanks again!
ID:	346757   Click image for larger version
ID:	346758   Click image for larger version
Old 12-22-2013, 10:53 PM
Default Correct Casting Number?
Bump. Does anyone have a 1965 GTO with the original rear end? Looking to see if this 9777142 casting is correct. Thanks!
Old 12-22-2013, 11:29 PM
Ck'ed one of my spiral notebooks from old builds & 9777142 was a casting number used on '65 Pontiac A-body housings. If the assembly date on the axle tube is not legible due to pitting, can always pull the cover drain the grease & read what date is on the ring & pinion.
Old 12-23-2013, 12:44 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Not sure where in Canada u are located but I have a 65 diff, out of a 65 Lemans. should be the same housing. Can look for numbers if wanted. Has 256 open. Might save a little on shipping??
64 Lemans hardtop
4spd, buckets
Old 12-23-2013, 01:03 PM
Default Please Do Check!
Hi there. if you don't mind, please check the numbers on your rear end. Please let me know numbers and price via Private Message. I have not yet committed to the other rear end.
Thanks!!
Old 12-24-2013, 01:10 AM
SR-71 SR-71 is offline
I have a really nice 1965 housing, casting 9779822 stamped WF (3.23 open) dated C255 (March 25th, 1965) that I would sell. It's apart and very clean in Ohio.
Old 12-29-2013, 10:30 PM
Default 9777142 Pictures
'ol Pinion head mentions earlier that the 9777142 rear end was used in '65 A-bodies. For your reference, I have a better picture of this housing below.
Does anyone own a 1965 GTO on this forum with a 9777142 casting rear end that is known to be original to your car?
I am really trying to get to the bottom of this casting number thing. Any help would be much appreciated. Thanks!
Old 12-30-2013, 02:34 AM
Lemans64's Avatar
Should maybe have this moved to the 64-65 section.
64 Lemans hardtop
4spd, buckets
Old 12-30-2013, 03:02 PM
Default I Agree
I agree. I would imagine this would be a decision of the Moderators? I can't find any options to move it myself. I have seen some threads on this forum dealing with casting numbers on '64 rear ends, but few on the '65 editions. If moved, this thread could serve us '65 owners well into the future.
Thanks!
Old 12-17-2025, 02:29 PM
Dee Dee is offline
Default 1965 gto
My 65 gto rear end 9777142 with 390 ratio
