Old 12-18-2013, 12:29 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Default Need some help with a Fiero
I have a 1988 Fiero Formula that a rodent chewed off the wire that goes to the O2 sensor. Try as I might, I cannot find where the wire goes into the wiring harness so that I can make a repair. Does anyone have a 1988 V6 car that could take a pic of the O2 wire where it comes from? Thanks!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 12-18-2013, 04:10 PM
critter's Avatar
critter critter is offline
Maybe this will help. From the factory service manual.
Name:	Screen Shot 2013-12-18 at 2.11.53 PM.png
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 12-18-2013, 07:10 PM
3tas4me's Avatar
Thanks! I have the factory manual but have not seen that diagram in it anywhere. I will give another look around the engine compartment.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 12-19-2013, 10:40 PM
JohnS66GTO JohnS66GTO is offline
Here's a picture from my original '88 engine. The O2 sensor wire comes out of the main harness that's covered with foil tape, near where it attaches at the engine / trans joint, right alongside the steel coolant tube.
John
Name:	IMAG0322 resize.jpg
1966 GTO Post Coupe, Barrier Blue / Parchment, 4-speed, A/C
1988 Fiero GT, T-tops, 5-speed, 3.4L engine swap
The Following User Says Thank You to JohnS66GTO For This Useful Post:
Old 12-20-2013, 02:04 PM
3tas4me's Avatar
Thanks to both of you for the help. I will get out there and see if I can find that wire now.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 02-25-2014, 08:00 PM
3tas4me's Avatar
I have searched and searched and still cannot find the wire coming out of the main harness. The above pic shows that it is clearly in the area where the trans harness branches off. Mine has disappeared!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 03-01-2014, 08:44 PM
It may have been chewed off right where it comes out of the main harness, and just pulled the remainder back into the conduit. Did you open the harness conduit?
John
Old 03-09-2014, 12:32 PM
3tas4me's Avatar
John
Finally opened it up yesterday. Per your picture and the service manual, the O2 wire appears to come out of the main harness where the fuel pump relay wires come out. Not on ours. We found the purple wire in the main harness and it continued down under the engine finally coming out not too far from the starter. Apparently ours was not built per what the manual shows. I pulled the wire back up and routed it where the manual shows it should be. Repair completed!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 03-10-2014, 12:04 PM
Glad you found the wire.
I like Fieros, and have owned 3, but one thing I notice on the '88s is that there seems to be a lot of variation in build quality. Unfortunately, almost 1/2 of the '88s were built after Pontiac announced the car was being discontinued (and internally at GM the writing was on the wall significantly earlier). So I have to believe the suppliers tried to find ways to ship, and get paid for, every single part they could. If it was functional, it probably shipped, regardless of whether it was 100% "right".
John
