Old 12-23-2013, 11:59 PM
keepat's Avatar
keepat keepat is offline
Default 2nd gen Leaf spring rebuild kit
Looking to rebuild my original leaf springs And looking for new plastic liners and spring clips, Anyone know who sells a rebuild kit.
Thanks & Merry Christmas
Pat
Old 12-24-2013, 02:14 AM
MG12692 MG12692 is offline
Send a message via MSN to MG12692
Try classic industries,ames,py. I went to pro touring F-body.com and replaced the leafs on my 72'bird and used the solid metal style pad instead of the rubber one.
Old 12-24-2013, 02:16 AM
LeighP's Avatar
LeighP LeighP is offline
Pro-Touring F-Body. They sell a fitting kit with HD shackles, bushes, J nuts/bolts and the HD replacement U bolts, urethane spring perch pads etc.
I'm sure if you don't want the whole kit, he'd probably split one up for the pieces you need.
Google up his website for contact details.
none of this stuff is OEM stock ,so if thats what you want, I'd hit up the site sponsor or Ames etc.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 12-24-2013, 09:06 AM
Norwood's Avatar
Norwood Norwood is offline
Only one place to get own style ones. Do a search in the 70-73 section for "spring" using my user name and a couple of threads will come up. I would post a link but I am just learning how to use this new phone of mine.
Old 12-24-2013, 09:26 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I think this is the post Norwood is talking about, another dead-on factory reproduced part from him:
http://forums.maxperformanceinc.com/...d.php?t=676536
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
The Following User Says Thank You to RicksGTO For This Useful Post:
Old 12-24-2013, 09:57 AM
165th's Avatar
165th 165th is offline
Here's a suggested method and how Norwood's spring clamps look on a fresh set of springs.
Dis-assemble the springs. Mark them so the left and right go back together properly.
Keep the rubber inserts under the spring clamps.
wirebrush to bare metal.
push new bushings in.
prime with zinc phosphate primer.
topcoat with OER High solids silver.
plastic spring spacers are available at Classic Industries. I haven't found them at PY or Ames.
Spring clamps are NORWOOD. They are perfect and accept the rubber insert perfect as well.
Good luck and have fun.
ID:	347448   Click image for larger version
ID:	347449   Click image for larger version
ID:	347450   Click image for larger version
Name:	Tempo primer.jpg
The Following User Says Thank You to 165th For This Useful Post:
Old 12-24-2013, 10:01 AM
165th's Avatar
Hold the phone... is that... Keepat that started this thread????
Are you back with another project?
Old 12-25-2013, 05:56 PM
keepat's Avatar
Just restoring the original leaf spring from the 72 T/A. Sorry no new Pontiac project but I will be starting on a 68 Dodge Charger soon!
Pat
Old 12-25-2013, 11:46 PM
Do you have a part number? I could not find them on their website....
Old 12-27-2013, 01:30 PM
165th's Avatar
The Classic Industries part no. for the plastic spring spacers for 4 leafs is K0097. K0098 for 5 leafs.
The reason you may be having a hard time finding it online is it's listed as a '67 ~ '69 part.
It's expensive because they do not sell the plastic parts by themselves, so you have to buy the metal spring clamps too, and then throw them away and use NORWOOD's.
The correct rear shackles for '70 ~ '73 on Classic Industries are also listed as '67 ~ '69 parts but our host has those handy.
Old 12-27-2013, 02:44 PM
Brad Pringle's Avatar
Brad Pringle Brad Pringle is offline
Default spring rebuild
I see 165th used wire brush. is there a disadvantage to sand blasting the leaf springs?
by the way your springs look great!
Brad Pringle
Wellston, Michigan
1973 SD 455 TA Auto
1974 SD455 TA 4 Spd
Old 12-27-2013, 03:19 PM
165th's Avatar
Thanks Brad. Sand blasting is fine if you have access to it. My blaster is across town, and you have to drop off, then return to pick up a day or so later, so I traded elbow grease for the convenience of blasting them. Blast away, but even more reason to need primer, to fill the profile left by the blast media.
Old 01-01-2014, 12:00 PM
Bentwheelbob's Avatar
Greg - Those springs look great. Where did you get your stencils? Did you make them or are they available somewhere?
Old 01-01-2014, 01:08 PM
165th's Avatar
Hi Bob, thanks for the compliments. The stencils are commonly found from the Hobby store. Size doesn't matter too much I don't think. Attached are a couple of examples of original stenciled numbers on springs compliments of one of my previous resto's and NJ Steve's springs on the white TA he used to own. The yellowed stencil is significantly smaller than the white one.
The PL and PJ stickers are home made. I'll be glad to send you a set if you'd like.
Attached is a pic of another set I recently finished. I've chose to put the painted stencil in a location towards the rear of the spring that can be a little easier to see when looking in the wheel well just behind the rear tire. It's a little darker and harder to see I think when placed in the front portion of the spring. Not sure if that makes sense.
Side note, this is my first post with large embedded pics included in the post. Thank you to JohnTA1 who recently posted the instructions of how to do this. So much fun!
Name:	1013 spring1 NJSteve.jpg
ID:	348136   Click image for larger version
ID:	348137   Click image for larger version
ID:	348138   Click image for larger version
Name:	gregs 73 brewster sd rear 3 sm.jpg
ID:	348139   Click image for larger version
Name:	Sister springs 2sm.jpg
Old 01-01-2014, 05:14 PM
Norwood's Avatar
Greg you are an arteeeest...
Old 01-01-2014, 05:41 PM
165th's Avatar
Thanks, but after all the fluffing of the rear end, what I really want for 2014 is for my car to sit just like yours when it's on the asphalt!
Old 01-01-2014, 06:06 PM
Norwood's Avatar
I want it sitting next to mine.....
Old 01-01-2014, 06:11 PM
Gator67's Avatar
Gator67 Gator67 is offline
I didn't detail my rear end or springs, but after looking at yours, I regret it. I too wish my car would sit down like Norwood's.
Old 01-02-2014, 12:55 PM
Mezzo's Avatar
Mezzo Mezzo is offline
Default Axle paint
Did you use the same OER high solid silver on the axle and brake drums? If so where was it purchased?
Old 01-02-2014, 02:45 PM
70RAlll 70RAlll is offline
Please post the OER part number and the primer part number you have used. Would like to use the same you used..Looked for OER hi solids and all I found was aluminum color?? Appreciate your help..
The Following User Says Thank You to 70RAlll For This Useful Post:
