Old 12-27-2013, 11:48 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Default My T/A Christmas gift
I sold my red Formula but kept the procharged 455 out of it, went through it, changed bearing, 236-244 solid roller, ported 4X heads with chambers opened up to 121cc (7.8 to 1compression)t-400 trans, 3.08 posi 10 bolt rear.ect... and droped it in this 81 Trans Am I've been working on for 3 years. Just finished it except with a few small details here and there. It only had 64,000 miles on it when the 301 expired and has been garaged ever since, soooo, no rust anywhere and no dents. The guy that I got the car from had it more than 10 years and just didn't want it and just gave it to me. We totally disassembled the car and I built it the way I wanted. 77-78 front nose, Changed the color from Charcoal to black. New interior, dash, 160 speedo, 8000 tach, Vintage air a/c, and Restore A Musclecar platinum T/A graphics. Body and engine is solid mounted with urathane bushings throughout the suspension. Stock sway bars with 600 lbs springs up front. On the chassis dyno I stoped it at 5000 rpms and the torque had just peaked at 567 lbs. It was table top flat in the 560's up to that point at 5000 rpm shut down. Hp was 540 with an agressive uphill curve. I didn't want to take it any farther as I already worked too hard on everything just to have to pull it all apart again. Yes it drives awesome and 100-120 mph is effortless. I've waited a long time for a car like this.
Steve
ID:	347697   Click image for larger version
ID:	347698   Click image for larger version
The Following 4 Users Say Thank You to p4msi1 For This Useful Post:
Old 12-27-2013, 11:59 AM
Hooter's Avatar
Hooter Hooter is offline
Sweet car.
67 Bonneville ragtop
Old 12-27-2013, 01:12 PM
hada76's Avatar
hada76 hada76 is offline
Originally Posted by p4msi1 View Post
I built it the way I wanted. interior, dash, 160 speedo, 8000 tach, Vintage air a/c
Steve
how was the A/C install? is the vintage kit complete? what stock parts are reused? thx
___________________________________________
the more im around people, the more i like my dogs
Old 12-27-2013, 01:35 PM
wheelspin's Avatar
Arrow
Nice build .
Les Iden
Old 12-27-2013, 03:11 PM
72projectbird's Avatar
What fuel cell is that?
The car looks great! That 455 is making some good power!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 12-27-2013, 04:39 PM
Nice looking TA.
I like that style hood Bird also.
Old 12-27-2013, 05:27 PM
jm455ho's Avatar
jm455ho jm455ho is offline
very nice
www.hobracing.com
Old 12-27-2013, 06:39 PM
grandville455's Avatar
grandville455 grandville455 is offline
Real Nice!!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 12-27-2013, 06:40 PM
modzx99's Avatar
modzx99 modzx99 is offline
SWEET!!!!
Old 12-27-2013, 06:50 PM
p4msi1's Avatar
Hada 76, I only kept the condenser coil, everything else went out. All of the system fits under dash but will not just plug into the existing vents. I had to fab aluminum transitions to all the vents and then holesaw the 3" holes for the a/c ducts to connect. At the firewall, I fabbed a 16ga cold roll steel plate to cover and smooth out the firewall where the old a/c evaporator system was.. It was easier to install because I was replacing the dash anyway. Just the dash replacement would be a 2 day event.
Old 12-27-2013, 07:00 PM
p4msi1's Avatar
72project, I fabricated the fuel tank in my shop. I own a metal fab shop and we do alot of stainless steel work in kitchens and hospitals so I built a 17 gallon stainless steel tank with a sump & baffle for the A1000 areomotive fuel pump with a return line. I made the tank narrow because I originally was going to run the exhaust on either side of the tank and out the back but when I mocked it up, it did not look right so I dumped the 3" exhaust behind the rear wheels. I like this t/a more than my 69 firebird.
Steve
The Following User Says Thank You to p4msi1 For This Useful Post:
Old 12-27-2013, 08:58 PM
Half-Inch Stud's Avatar
very nice
Old 12-27-2013, 09:35 PM
7t8ta 7t8ta is offline
Looks great! The platinum bird looks great.
Old 12-29-2013, 10:47 PM
MG12692 MG12692 is offline
Send a message via MSN to MG12692
Doin a Vintage Air swap in my 72' bird right now and my hats off to you. Since they don't offer a second gen firebird kit I purchased a 70-81 camaro kit. The only thing that fit was the evaporator, everything else and I mean everything else was modified to work.
Old 12-30-2013, 12:08 AM
demonic68's Avatar
demonic68 demonic68 is offline
Good looking car man
Old 01-01-2014, 08:25 AM
p4msi1's Avatar
MG, installing all the interior part of the Vintage air was hard but the real challenge was finding a location for the A/C compressor and building the brackets. The D1SC procharger is on the passenger side of the engine and the power steering/ alt. is on the driver side, no room underneath, so it got squeezed between the alt. and procharger. Chop-Cut -Rebuild.
Steve
