pick up in davison mi 48423 or i will ship payment must be us money postal order or paypal some of the larger items i would prefer not to ship but if your serious and understand shipping on large items is going to be expensive i will consider it if you have any question email me at [email protected] or call/text 810 962 4569 most parts came from 77-81 cars unless otherwise noted i have about half of these parts listed on ebay i can send pictures via text or email but i will not play the game of sending 1000 pictures sorry ive had to many people waste my time doing this
75-81 passenger side seat track 75 dollars 18 available 75-81 seat track set 220 dollars 6 available 71-74 passenger side seat track 125 2 available 71-74 seat track set 300 dollars 3 available Door hinges with new bushings and pins installed 70 dollars a set 2 available Fischer t top bags 80 dollars per pair 2 pair available Pontiac motor mounts 80 dollars per pair 6 available Pontiac thermostat housing 5 dollars each 13 available Pontiac rocker arms 5 dollars each 20 available Pontiac power steering bracket 350-455 50 dollars 7 available Pontiac oil filter adapter 50 dollars 6 available Pontiac 301 power steering bracket 25 dollars 2 available Pontiac Push rods 2 dollars each 20 available Pontiac Timing tab 20 dollars 3 available Pontiac starter wire tube 15 dollars 6 available Power steering pulley 20 dollars 17 available Pontiac water pump pulley 20 dollars 13 available Pontiac crank pulley 20 dollars 11 available Pontiac alternator bracket 40-100 dollars many different styles available Throttle cable bracket 20 dollars 4 available Pontiac dip stick 20 dollars 1 available Pontiac distributor hold down 10 dollars 6 available 301 turbo intake 50 dollars 1 available 301 turbo valve cover 60 dollars per pair 1 pair available 301 turbo dip stick 20 1 available 301 turbo valley pan 60 dollars 1 available 301 turbo cable bracket 25 dollars 2 available Pontiac flex plate 40 dollars 1 available Pontiac fuel centric 40 dollars 3 available Pontiac exhaust manifold heat shield 40 dollars 1 available Edelbrock performer RPM intake NEW 200 dollars 1 available 70-76 fender to core support brace 40 dollars per pair 1 pair available Misc. 403 Oldsmobile a/c brackets 25 dollars each 2 available 403 olds crank pulley 40 dollars 1 available 403 olds water pump pulley 40 dollars 1 available 403 olds timing tab 20 dollars 1 available 403 olds alternator bracket 40 dollars 1 available 403 olds motor mounts 80 per pair dollars 1 pair available Small block Chevy motor mounts 40 dollars per pair 4 pair available Small block Chevy a/c brackets 100 complete set 1 available Small block Chevy a/c brackets 30 dollars each 6 available Pontiac oil pan 60 dollars 6 available 74-78 taillights 100 dollars per set 2 sets available 79-81 taillights 300 dollars per set 3 sets available Seat backs 50 dollars each 9 available Pontiac valve covers 60 dollars per pair 2 pair available Fender cut outs with extractors 100 dollars per pair 2 pair available Core support brackets 20 dollars each 10 available Shelf 2 71-73 seats complete set need recovered 200 dollars 1 available 70-73 rear valance 100 dollars 2 available 70-73 front valance 150 dollars 2 available Non a/c blower motor housing 50 dollars 2 available 400 turbo transmission cross member 100 dollars 2 available 4 speed or 350 turbo transmission crossmember 60 dollars 3 available Intermediate shaft 75 dollars 4 available Visor mounting brackets 10 dollars each 25 available Windshield trim chrome 50 dollars a set 4 sets available Rear trim 75-81 50 dollars a set 2 sets available 70-74 rear window trim 150 dollars a set 70-76 drip rail trim 100 a pair 2 pair available Shaker ring 40 dollars 2 available Fan with clutch 30 dollars 1 available Fisher t top latches 60 dollars a pair 1 pair available Remote mirror bezel 10 dollars 3 available Tilt lever 10 dollars 2 available Fischer t top latches 60 dollars a set 3 available Rear ash tray 10 dollars 10 available Power window switch 30 dollars 3 available Power lock switch 15 dollars 15 available Gauge rings 35 dollars a set 5 available Lighter nut 10 dollars 10 available Large gauge rings 5 dollars each 10 available Sill plates NIB 40 dollars a pair 2 pair available Torsion trunk rods 50 dollars a pair 3 pair available Black windshield trim 50 dollars a set 5 available 75-81 black rear trim 50 dollars a set 5 available 74-76 coolant jug 75 1 available Power window boots 25 dollars each 12 available Power window/lock wiring 60 dollars 1 available Hurst 4 speed shifter 200 dollars 1 available Remote mirror 80 per pair 1 pair available 8 snowflake refurbished 77-78 SE rim 500 dollars per set 1 set available 8 snowflake rims 400 dollars per set 1 available Reverse lock out auto 60 dollars 4 available Revers lock out cup 15 dollars 3 available Reverse lock out swivel 25 dollars 2 available Trans cable bracket 15 dollars 2 available Trans gear selector bracket 15 dollars 5 available 74-76 coolant jug bracket 50 dollars Crossmember bracket 25 dollars 5 available Converter bracket 60 dollars 5 available Pontiac flywheel 50 dollars 1 available Parking brake 25 dollars 1 available Tail pipe hanger 15 dollars 5 available Rear end bump 20 dollars 6 available Pinion bumps 20 dollars 2 available Trunk lock mechanism 15 dollars 3 available Shackles 20 dollars a set 1 available Windshield holds 5 dollars 7 available Passenger side door latch 25 dollars 2 available Rear sway bar to frame mounting bracket 10 dollars 17 available Rear sway bar bracket bar to mounting pad 10 dollars 17 available Rear sway bar drop link 25 dollars 14 available Ws6 subframe bars 30 dollars each 16 available SHELF 3 Glove box door 50 dollars 2 available Steering column cover 50 dollars 2 available Center console back plate 10 dollars Seat belt cover t top 50 dollars per pair 79-81 headlight bezels 10 dollars each 14 available Cowl screen 10 dollars 5 available Front backing plates 40 dollars per pair Cruise control module 20 dollars 3 available Ash tray 30 dollars 5 available 71-77 arm rest bracket 10 dollars each 6 available Front speaker bracket 10 dollars Steering hub 20 dollars each 7 available Side mirror hardware set 30 dollars 4 dollars Side mirror brackets 20 dollars a pair 5 available Side mirror bracket driver side 10 dollars Side mirror gasket 10 dollars 70-76 heater control bracket 15 dollars each 2 available 80 81 front speaker grills 20 dollars a pair 2 pair avaolable Rear speaker grills 80 dollars a pair 2 pair available Hood popper 5 dollars each 9 available 77 air intake firebird/Camaro 55 dollars Radiator bumps 5 dollars each 26 available 74 one year only turn signals 150 doll.ars per pair Hood latch 15 dollars each 12 available Hood latch 74-76 50 dollars each 2 available 79-81 hood latch cable bracket 25 dollars each 4 available 77-78 hood latch cable bracket 25 dollars each 2 available 77-81 center bumper bracket 10 dollars each 8 available 74-76 center bumper bracket 10 dollars 77-81 side bumper bracket 10 dollars each 7 available 80-81 front speaker brackets 20 dollars a pair Core support to bumper bracket 10 dollars each 6 available 79-81 core support to bumper bracket 10 dollars each 13 available Windshield wipers 25 dollars a pair 12 pair available Windshield wiper arm passenger side 10 dollars 77-81 headlight buckets 10 dollars each 10 available Horn contact 15 dollars each 8 available A/c actuator cowl panel 25 dollars each 3 available A/c actuator kick panel 25 dollars each 11 available A/c kick panels 80 dollars a pair 3 pair available Sail panels 100 dollars a pair 3 pair available Center console 100 dollars each 2 available 71-77 seat backs 40 dollars each 3 available Rear arm rest 100 dollars a pair 6 pair available 79-81 steering columns 75 dollars each 6 available 70 78 steering column 125 dollars each 2 available 70 78 steering column non tilt 60 dollars each Hush panel 50 dollars each 7 available Grab bar 20 dollars each 2 available Wiper transmission 20 dollars each 5 available 70-73 headlight plates 30 dollars each 10 available 70-73 headlight trim 10 dollars each 5 available 70-73 fuel door 40 dollars 70-72 grill brackets 60 dollars 73 grill brackets 60 dollars 70-74 a pillars 80 dollars a pair 70-73 front bumper L brackets 125 dollars a pair 3 pair available Headlight buckets 20 dollars each 6 available Turn signal grill 15 dollars each 6 available NIB interior screw set 70-73 15 dollars Taillight housing 40 dollars a pair Headlight bezels 30 dollars each 4 available Taillight grills 60 dollars a pair 2 available 73 amber turn signals 100 dollars a pair 2 pair available 70-72 turn signal housing 50 dollars a pair 70-73 turn signal bezels 40 dollars a pair 3 pair available 72 grills 250 dollars a pair Rear end plates 15 dollars each 12 available Fender extensions 50 dollars per pair 10 pair available Inner fender brackets 20 dollars a pair 4 pair available Leaf spring pocket brackets 50 dollars a pair 3 pair available Non a/c vents and dash tubes 50 dollars Gear box cover 2 piece set 25 dollars 6 available Gear box cover upper shaft cover 10 dollars 3 available Gas pedal with bracket 10 dollars Ws6 gear box 75 dollars 3 available 301 turbo air scoop 75 dollars 2 available Clutch pedals 75 dollars 1 available Auto brake pedal 40 dollars Z bar bracket 15 dollars Marker light bezels 20 per set Seat belts 125 dollars per set 4 sets available Visors 30 dollars each 10 available Headlight switch 5 dollars 6 available 70-76 under sill plate 80 dollars per pair 77-81 under sill plate 80 dollars per pair 77-81 under sill plate passenger side 30 dollars 2 available Intake tube lower 25 dollars 6 available Intake tube upper 50 dollars Radio from 81firebird 50 dollars Shaker Pontiac 400 125 dollars 2 available Shaker Pontiac 400 77 only 175 Shaker Chevy 305-350 200 dollars Dash a/c vents 30 dollars 6 available Rear defrost switch 25 dollars 7 available Horn button 30 dollar Air filter elbow 30 dollars 2 available Map pocket 30 dollars 9 available Trunk pop button 20 dollars 6 available Like new Pontiac starter 15 dollars 2 available 6x heads Pontiac 350-400 50 dollars per pair 2 pair available 79-81 wiring from fuse box up to taillight wiring 15 dollars 79-81 taillight wiring 20 dollars 3 available 301 turbo ecu to distributor wiring 80 dollars 301 turbo a/c wiring 50 Power window/lock wiring wireing 60 dollars 2 available A/c wiring 30 dollars Camaro a/c wiring 30 dollars Non a/c defrost duct 35 dollars 2 available A/c defrost duct 20 dollars 3 available shelf 4 79-81 taillight nuts 1 dollar each 90 available Seat track covers 5 dollars each 26 available 77-81 a/c controls 75 dollars each 6 available 78 Camaro hood latch 30 dollars Like new grant steering wheel 50 dollars NIB Pontiac starter 25 dollars Camaro parking brake 25 dollars 70-77 camaro fuel door 20 dollars 78 rear bumper ends 80 dollars per pair NIB camel carpet and underlayment 140 Speedo/tak 80 dollars each 3 available Rear shelf juke NIB 10 dollars Trunk seal NIB 10 dollars Brake pedal pad NIB 5 dollars Gas pedal bezel NIB 5 dollars Brake pedal bezel NIB 5 dollars Emergency brake pedal pad NIB 5 dollars Gas pedal pad NIB 5 dollars Emergency brake pedal bezel NIB 5 dollars Chrome radiator support 20 dollars 2 available one is NIB Core support bushings NOS 30 dollars for the pair Fan switch NOS 30 dollars Seat belt loop 5 dollars each 5 available Brake distribution valve 4 wheel disc brakes 30 dollars 4 available Hood latch cable 20 dollars Camaro center console 50 dollars T top U trim 100 dollars per pair 4 pair avalible Door handle cups 10 dollars per pair 75-81 a pillars 30 dollars per pair 18 pair available Camaro fender braces 10 dollars per pair 77-81 fender braces 10 dollars each 26 available 78-81 arm rest 100 dollars per pair 5 pair available Shifter nob SE gold bird 40 dollars 2 available Shifter nob Pontiac head 40 dollars 2 available Shifter nob old school bird like on 69 40 dollars Shifter nob red bird 35 dollars 5 available Shifter nob insert red bird 15 dollars 2 available Camaro shift nob 20 dollars Non a/c dash bezel bird emblem 15 dollars 6 available Pulse wiper switch 20 dollars 3 available Non pulse wiper switch 5 dollars 3 available Emergency brake release 15 dollars 8 available Gauge cluster wiring 10 dollars Water/oil gauge 25 dollars Fuel/volts gauge 25 dollars 4 available Door rods 10 dollars 3 available Plugs for non-power window door 5 dollars each 4 available Plugs for non-power window body 5 dollars each 5 available Posi tag 5 dollars Hood hinges 75 dollars a pair 11 pair available Trunk popper 20 dollars Shifter bump style 80 dollars 9 available Shifter regular 50 dollars 4 available Non a/c heater controls 100 dollars 70-76 heater controls trans am 100 dollars Non a/c heater control cables 20 dollars Jack set up 100 dollars 3 available Camaro seats blue cloth complete set 150 dollars Door panel blue Camaro 80 dollars Pontiac condenser 100 dollars 2 available A/c suitcase 100 dollars 6 available A/c duct work 10 dollars each 11 available excluding tube under steering column and behind radio A/c tube behind the radio 70 dollars 6 available a/c tube lap duct 70 dollars 5 available A/c lines 25 dollars Holley electric blue fuel pump 75 dollars Door J rods 5 dollars each 7 available Misc. bolts clips and fasteners .25 to 5 dollars each Radiator hold ins 5 dollars each 8 available RTS emblem on dash bezel 10 dollars 3 available T top trim clips 75 dollars a set 3 sets available Front seat belt buckles 15 dollars each 3 available Rear seat belt buckle 10 dollars 75 foglight deletes 30 dollars per pair 74-76 front upper bumper brackets 50 dollars per pair 74-76 front bumper L brackets 75 dollars per pair 80 81 z28 camaro hood air cleaner adapter 25 dollars 74-76 front liscense plate bracket 25 dollars 74-76 front bumper bracket middle 30 dollars 74-76 front bumper to core support brackets upper 20 dollars each 3 available 74-76 front bumper bracket to core support lower 25 dollars per set 78-81 camaro headlight buckets 10 dollars each 3 available 74-76 rear bumper brackets 40 dollars per pair Shelf 5 Dash bezel 30 dollars 70-74 driver side sail panel 30 dollars Center console 50 dollars Lower intake tube 10 dollars Outside 7 snowflake rims with tires 150 dollars per set 78-81 seat backs 20 dollars per pair 7 snowflake rims without tires 25 dollars each 5 available 8 snowflake rims without tires 75 dollars each 3 available 8 turbo rims without tires 300 dollars per set Deck lid 40 dollars 7 available Front sway bar 40 dollars 2 available 70-72 nose 125 dollars 2 available Core support 100 dollars 4 available 79 rear bumper 50 dollars 74-76 front nose 25 dollars 79-81 front bumper 50 dollars Passenger side under sill cover 20 dollars SBC water pump pulley 10 dollars 77-78 rear bumper 50 dollars Automatic drive shaft 40 dollars 2 available Manual drive shaft 75 dollars 6 available Back glass 50 dollars 8 available 79-81 air dam 75 dollars 1 available A/c heater core housing 20 dollars Console 40 dollars Firebird taillights 79-81 20 dollars 74-78 taillights 25 dollars a pair 4 pair available 79-81 rear flares 20 dollars each 1 available Trans cooler 15 dollars 4 available Hood hinges 20 dollars a pair Fan shroud 100 dollars 3 available Chevy bell housing 50 dollars Rear spoiler middle 30 dollars 70-73 spoiler ends 60 dollars per pair 74-78 spoiler ends 50 dollars per pair 3 pair available 79-81 spoiler ends 30 dollars per pair 2 pair available Passenger side toe panel 50 dollars T top trim 60 dollars 14 rally rim 20 dollars Shaker hood 75 dollars 2 available Side glass 20 dollars each 10 available Gold t tops on y88 200 dollars a pair T tops Fischer 50 dollars a pair 4 pair available Inner fenders 30 dollars each 9 available Cowl panel 60 dollars 2 available Trunk pocket sheet metal 60 dollars Leaf springs 100 per pair Camaro inner fenders 40 per pair T top roof 50 dollars 2 available Rear sway bar 40 dollars 5 available Bins 75 owners manual 10 dollars Pontiac hei distributor 10 dollars 70-72 turn signal housings 20 dollars Large dash rings 5 dollars 7 available Cigerate housing dash bezel 10 dollars 1 available Camaro a/c duct work 10 dollars 2 available Kick panel actuator 10 dollars 2 available 350 turbo kick down cable 10 dollars Gas tank strap 10 dollars 2 available Coolant jug 20 dollars 1 available Door jamb vents 5 dollars 5 available Passenger side mirror 15 dollars 3 available Driver side mirror with remote 25 dollars Throttle cable 10 dollars 3 available Trans gear selector cable 10 dollars Glove box door 10 dollars 1 available Ash tray 10 dollars Lower intake tube 10 dollars T top trim 15 dollars each 4 available Front marker light 5 dollars Horn button center emblem 10 dollars Fender extensions 10 dollars 2 available 77 chevy 4 speed carb 80 dollars 73 olds 4 speed carb 80 dollars Steering column cover 10 dollars Gauge cluster 15 dollars Carpet guard behind pedals 10 dollars 2 available Volts and fuel gauge 10 dollars Windshield wiper bottle with motor 10 dollars 3 available Windshield wiper bottle without motor 10 dollars 2 available Glove box insert 10 dollars Passenger side fender vent 10 dollars T top handle RH 10 dollars |
PM sent
I dont get paid for another week but id be interested in tha few parts. The t top bags those will fit a 81new t top right? The set backs for 20. And then i was wondering do u have a cruise/ turn signal lever for a 8181 ta. Thanks ben
i have a couple sets of t top bags yes they are for the fischer t tops 78 to 81 i do not have a crusie control/ turn signal lever for an 81 thank you, adam |
lots of parts still available
Are any of the rear sway bar drop links the early style?
I'm looking for Navy or Dark Blue sun visors. What colors you have?
Do you have any 80 houndstooth dark blue seats? thanks chaz069
Sorry I meant dark blue hobnailcloth seats. Thanks chaz069
Sent you a PM about a cluster housing.
PM sent on Air cleaner adapter
2-1962 Lemans convertibles 4cyl, auto 1962 Tempest safari wagon (running project) 1972 455 Formula (tribute) 1962 Skylark convertible 215 4-barrel , auto 2009 G8 Sport red metallic, Onyx leather Whatever else that make my way into the driveway |
PM sent on 71-77 seat backs.
Is the air cleaner adapter still for sale? Waiting on your response to email.
Do you have a power antenna that will work in the drivers fender of my 81 TA? Thanks
79 trunk Corner spoilers still available?
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
pm sent
