Old 01-05-2014, 05:43 PM
1966geeto 1966geeto is offline
Default Vacuum advance
Finaly got some extended run time on the eng man she is sweet even moves lol I am running an Edlebrock performer series carb both vacuum ports are wide open at idle if I hook them up I have full advance is there any other options you guys know of .If memory serves me the advance should be ported.The only other issue I had was fuel press gauge reading 0 it's a liquid filled gauge brand new just wondering if the stock pump has enough pressure to make it read ? increments of 5psi.
Thanks for any help
Old 01-05-2014, 07:44 PM
squidtone's Avatar
squidtone squidtone is offline
'geeto,
If you have a stock type distributor and stock vac advance, it should be connected to full manifold vacuum. Manifold vacuum is usually one of the ports on the throttle body (baseplate) of most carbs I think. Should check it though to be sure.
Dave
http://www.squidsfabshop.com/?
(updated January, 2013, Pypes exhaust installation)
Old 01-05-2014, 07:47 PM
GT182's Avatar
GT182 GT182 is offline
My vacuum advance is hooked to the back side of my Carter AFB Competiton Series carb. Was the same for the points distributor as it is for the HEI I'm now running. Note: I don't have power brakes so that's the reason it's pluged to the rear of the carb.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 01-05-2014, 07:54 PM
fyrffytr1's Avatar
I cannot hook my vacuum advance to full manifold vacuum. The car just won't run right. I have it hooked to a ported line on my carb and the engine runs much better. I guess my question is why would one want full advance at idle?
Old 01-05-2014, 07:57 PM
GT182's Avatar
As far as I know you don't. Not sure if mine is hooked up so it's at full advance or not, but it runs fine so far.
Gary
Old 01-05-2014, 09:39 PM
squidtone's Avatar
Hey guys,
I went through this when I re-did a whole new quadrajet for my car, and I also completely rebuilt my original points distributor (but I still am using the original vacuum advance that is had.) My QJ is from a 79 Trans Am so I wasn't quite sure what port the distributor can should go to, so I did some internet research. I found various answers, but the best was from a paper purported to be by a "GM engineer". Yeah, I take these sort of things with a grain of salt, but I have to say I found the arguments compelling. For me, manifold vacuum advance works perfectly. My car runs cool, it hasn't pinged yet. It starts so nice too.
Don't forget to time the distributor with the vacuum disconnected.
Here's the text from the "GM engineer".....
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Dave
The Following 2 Users Say Thank You to squidtone For This Useful Post:
Old 01-06-2014, 01:22 AM
GT182's Avatar
Squid, so he's saying any of the small vacuum ports at the base of the carb are ok for full vacuum.... including the rear port. Maybe even the hollow carb stub too if you have one?
Gary
The Following User Says Thank You to GT182 For This Useful Post:
Old 01-06-2014, 10:23 AM
c sheeder c sheeder is offline
the vacuum advance should be hook to a port that DOES NOT PULL VACUUM AT WOT(wide open throttle) at wot there should b no vacuum at the distributor...that is where mechanical advance comes in
Old 01-06-2014, 11:17 AM
Kenth's Avatar
Kenth Kenth is offline
At WOT it´s preferable to have no vacuum at all in the intake.
The centrifugal (mechanical) timing advance starts at approximately 1000 rpm and is present all the way.
The vacuum advance is an engine load sensor device adjusting the timing depending on engine load.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-06-2014, 01:24 PM
If you have any vacuum at WOT somethings wrong it was that the last cars I worked on with vac advance were smog cars and I remembered them being ported static timing usually run 10 degrees so with the full advance at idle it's running 28 degrees seems to have a sweet spot there what are you guys running total timing with pump gas.Thanks for the schooling refresher course makes sense.
Old 01-06-2014, 01:29 PM
squidtone's Avatar
Yes, I'm not sure if some carbs may have a port on the throttle body (baseplate) that is actually some other vacuum signal. So I would just be sure the chosen port actually pulls a nice vacuum at idle.
My takeaway from the article is that all contemporary auto engines of the pre-emissions era use manifold vacuum. Good luck!
Dave
The Following User Says Thank You to squidtone For This Useful Post:
Old 01-06-2014, 03:58 PM
geeteeohguy's Avatar
A hollow carb mount stud like the factory sometimes used is a good place to get manifold vacuum for the distributor. I run both of my GTO's on manifold vacuum, as originally designed. Manifold vacuum at idle allows for cooler running in traffic and better throttle response off idle at low speeds. As stated, it goes away at WOT when intake vacuum drops to near 0, and the vehicle relies on the centrifugal advance. Some cars run rough on manifold vacuum if the initial base timing is set too far advanced.....say at 15-18 degrees instead of 6 degrees. FWIW.....
Jeff
Old 01-06-2014, 05:11 PM
66 Gas Tires Oil's Avatar
66 Gas Tires Oil 66 Gas Tires Oil is offline
that GM paper is from the team chevelle web site. since there are way more chevelles there is more people there with answers. i have been on that site over ten years. true pontiacs are different that chevies but the answer is to try both and see what works for your application. use seat of the pants or a stopwatch. true one way may run cooler but do what makes you happy in the end. getting your distributer recurved and tuned with the correct springs for the proper mechanical advance is a good starting point.
Jim
