Video of the car idling:
http://www.youtube.com/watch?v=msVc4...ature=youtu.be I have said it before but here are specs: 2802 camshaft Pontiac intake, port matched 670 heads, ported (unknown cfm) Cliff QJet Flowmasters Summit headers, H-pipe stock rockers stock rebuild Very excited, cant wait to drive it with new intake on. Had a P4B on it. |
Very nice...400 or 455ci?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
400ci
Sounds good the car also looked good to man.
Sounds and looks great! Nice color too.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Thanks guys, appreciate it. I've had a hand in/done every part of it so it means a lot to me.
Car ran a 14.8 with 2.56 gear, 600cfm Eddie carb, 2801 cam. I think with poncho intake , 2802 cam and cliff qjet, it will be much better. |
It sounds awesome!
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. ![]() |
Real nice idle. I looked at your other videos, too. Nice burnouts
1972 Pontiac Lemans 350 Qjet Summit 2800 |
That's hot. I love the early 2nd gen formula treatment on the 79+ body. Your subtle and minimalist narration at the end was classic!
Thanks! Load up and drop the clutch!
The 2802 needs a little gas to break tires loose. It also had a spacer with a p4b which might affect power down low. 2801 didn't need as much gas to fry tires. Keep in mind though she has a 2.56! |
The Following User Says Thank You to Young Pontiac Guy For This Useful Post: | ||
so when are you doing a gear change. =) engine sounds great.
Nice looking car. Nice sounding (and looking) engine as well.
Gear change coming soon. Probably 3.23.
3.23 at the minimum. Sounds great!
1968 pontiac lemans 400. 13.16@102/8.5:1 /6x-4/lunati bm 2 cam/ 3500 stall/3.55 gears. |
YPG... Nice running car, I'll have almost the same deal in my 73, I have Butler ported 670's that flow around 245-250 cfm if I recall, combustion chambers opened up to 78cc. Summit 4 tube headers, 72 intake and Q jet, 406 CID.
I was looking at the 2802 or the simular Crower. It's auto right now but if I can line up everything for a 4 spd swap I'm going that way.
1974 Formula 400 "retired", parts car now. ![]() |
Pontiac One,
thanks for posting. Car runs well as it is. Pulls strong. I dont shift it over 5200rpm due to the stock rebuilt bottom end. With the 2802 it really starts pulling at 2700rpm, although it has torque down low. With the 2801 cam, it started pulling hard at about 2200rpm. Still much better with the 2802 cam. Friend of mine runs the 60243 Crower cam in his 406 Judge. That bad boy pulls like a freight train too. He has 1.65 rockers on it, shifts about 6000rpm. Either way is good. If I rebuild mine, it will likely get the Crower cam. That being said, you cant beat that 2802. I think results would be close with it after riding in his car, IMO. He doesnt have any numbers track wise on his car, nor will he. Might want to get Cliffs opinion on Crower vs Summit via pm, he would have a better opinion. One thing I forgot to add- I always run premium blended with 110 or 112. About 30% 110. Joel |
Sounds nice! Just right.
Black 1978 Trans Am SE Clone Butler Performance 474 E heads Built 400 Trans with 3000 stall 17" Y/O 1978 Y88 4 Speed T Top PHS Docs Restored 1987 Grand national 4.1 Stroker Motor Just a 6 Cylinder Buick |
![]() Quote:
Jack
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
That 2802 in a high compression 400 with ported heads should pull strong right up close to 5800-6000, they have been known to easily pull to 5600 in a similar 455
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
Another angle on 2802 performance in a 455 around 9.5:1 with 240 cfm D ports and a Street Dominator intake w 800 Qjet and headers in a 73 Ventura that had 2.73 gears. He was street racing a 2000 LS1 Trans Am that was a consistant 12.0 @ 112 car at the track and with the Ventura hauling 4 adults it was dead even from a punch all the way up to triple digits speeds with LS1 car that had solo driver on the hose.. it was a stock LS1 automatic car with NOS and drag radials.. So it seemed the Ventura had the HP and rev's to be a 11 second car , my best was 12.1@110 in my sig with a old motor in a 80 Bird. it didnt have the porting the Ventura had.
