Old 01-08-2014, 07:25 PM
Mike S's Avatar
Mike S Mike S is offline
Default Hood scoop and AF ratio
I have been having a problem last year. It would be rich for first gear (10.8). Then slowly come up to 12.8-13.2 by the middle of second gear and stay there for the rest of the run. Same with or with out the PV. If I lean the jets it has better 60's but looses mph and runs leaner top end.
I was thinking. Could I be getting more air at speed leaning the carb? Even with a cowl scoop? Anyway to fix the problem?
Old 01-09-2014, 08:09 AM
grandville455's Avatar
grandville455 grandville455 is offline
Mike Look into this....
http://racingfuelsystems.myfunforum.....php?f=25&t=15
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 01-09-2014, 09:46 AM
charlie66's Avatar
Maybe try a smaller pumpshot - squirter?
My Half AN Injun.....
Old 01-09-2014, 01:20 PM
AG's Avatar
AG AG is offline
The pressure generated going 130 mph at 60°F is only 0.3 psi, very little supercharging effect.
Old 01-09-2014, 02:03 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Originally Posted by grandville455 View Post
after skimming thru the link, I did not see any back to back tests listed that improve a/f ratio thru the engine cycle? One thing noticed, bars going across the top of the carb that would disrupt air flow into the carb would be bad.
Old 01-09-2014, 02:55 PM
...Maybe not that particular thread , but on the old MSV forum there was guys talking about a change in A/F after adding the flute
Jc, This is a response from jmark(mark whitner) on that forum about the Flutes
It is used when turbulence causes pressure fluctuations at the vents. The bowl vents provide atmospheric pressure that pushes fuel in through the carb. When there is turbulence at the vents from a poor scoop design it will disrupt the fuel curve making it erratic and most of the time you see the fuel curve go lean. Adding vent tubes like shown will fix it if there is a problem, and have no impact if there isn't.
Darby
Old 01-09-2014, 03:38 PM
J.C.you's Avatar
I could see doing the old sparkplug boot trick with the inlets pointed toward the bowls helping..... There is a reason vents are cut on a *45 angle away from the center of the carb.
Old 01-09-2014, 05:17 PM
cgeise's Avatar
cgeise cgeise is offline
Id try jetting for good early numbers then air bleeds to get fuel curve correct - MAKE SURE THE FUEL SYSTEM IS ADDIQUATE and your not leaning down due to fuel volume down track.
The Following User Says Thank You to cgeise For This Useful Post:
Old 01-11-2014, 08:37 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Find a chassis dyno and run it there where the car a just stationary. It will eliminate the scoop turbulance factor. If it does the same thing just do what Curt posted. I believe it will at least point you in the right direction in finding the solution.
Steve
Old 01-11-2014, 09:01 AM
mjm421's Avatar
mjm421 mjm421 is offline
Or cam. 30 or 50 cc pump?
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
Old 01-11-2014, 11:42 AM
charlie66's Avatar
When I think about it, it seems almost like a residual thing. Maybe its burning off excess fuel from the mechanical pump area. I mean how long is anyone in first. I know as soon as I launch I hit second or I go slower. If you don't like 13.00 + at the top of 3rd then just add a couple of sizes in the back And drop the front.. Anyway, Just a quick thought..
Good luck. you will figure it out....
Old 01-11-2014, 05:16 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Steve
I like this ^^^^ line of reasoning.
To add to that,try it w/the hood on -and- w/the hood off as well.
Could be a clearance issue as well,have heard of some lightweight glass hoods getting "sucked down" and reducing carb airhorn 2 hood clearance during a run.
FWIW
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
