Old 01-09-2014, 01:46 AM
3goats's Avatar
3goats 3goats is offline
Default Sealer question
Could you use ppg DP50lf as a sealer with using OMINI BSX 3.5 base coat clear coat paint on top without problems. This is for a driver car and have dp 50lf and dp401lf in stock and want to use it up. Thanks paint guys in advance for help.
Old 01-09-2014, 11:38 AM
6804gto's Avatar
6804gto 6804gto is offline
I wouldn't think you would have a problem. I would reduce it a little with some dt 885 so it lays down a little better. Check the p- sheet on reduction if you have it
5-10% I think
Old 01-09-2014, 11:53 AM
3goats's Avatar
The sheet says for sealer go 1:1:1/2 DT reducer . I have dt870 to use. Thanks for the reply.
