Old 01-12-2014, 09:40 PM
smakcruiser smakcruiser is offline
Default No Compression #8 Cylinder 66 2+2 :(
Back in September I was driving around my car like I normally do a few times a week and all of a sudden it just started running terribly. So I took a compression tester to the cylinders and all are in the 130s except for #8. I can't get over 10 psi out of it.
I have recently moved and my new garage is heated so I can work out there all year around, so I would like to take it apart and see what is wrong. The motor has about 40K on it I believe.
Without tearing it apart, obviously I can't determine what is wrong, but when you get symptoms like this is it re-build time or could something else be wrong that does not require a re-build? I am just hoping for the latter because I can't afford a re-build right now haha.
Old 01-12-2014, 09:46 PM
Stuart's Avatar
Stuart Stuart is offline
Have you taken off the valve cover yet? Look for a valve stuck open.
Old 01-12-2014, 09:48 PM
I apologize, I forgot to mention that... yes I have. Nothing weird in there.
Old 01-13-2014, 12:26 AM
kwt63cat kwt63cat is offline
Default no compression #8..........
With the valve cover off, watch the valve action as someone cranks the engine. If that looks normal, with #8 at TDC on the compression stroke introduce some compressed air into the spark plug hole of #8. (I made an adaptor to do this by brazing a quick coupler nipple to an old spark plug that I busted the porcelain out of.) Listen to the exhaust, Intake, and crankcase breather to determine the source of the problem. You can introduce compressed air into a known good cylinder for comparison purposes. Good Luck
The Following User Says Thank You to kwt63cat For This Useful Post:
Old 01-13-2014, 10:45 AM
ok. So I put some compressed air into the cylinder this morning and all I hear is a loud hissing somewhere in the crankcase area. I do not really hear anything with cylinder #6. Hmmmm...
Old 01-13-2014, 10:59 AM
geeteeohguy's Avatar
It could be a flat cam, bent pushrod, hole in the piston, or, more likely, a burnt exhaust valve. Try a leakdown test to verify, after you check for a flat cam.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 01-13-2014, 11:29 AM
I just yanked the intake and valley pan off. Pulled Rocker arms. All the push rods look ok. Cam looks ok visually...
Old 01-13-2014, 12:59 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
You basically did a leakdown test. Air is escaping in to the block through a hole or crack in the piston, cylinder. or gasket.
Old 01-13-2014, 02:36 PM
I think the next step then is to pull the head and see what is happening. What are my best and worst case scenarios here???
Old 01-13-2014, 02:56 PM
At this point it sounds like a head gasket or a problem with the reciprocating part of #8. Pull the head and check things out. Best case scenario? Bad head gasket leaking to the valley area of the engine or to the oil return galley from the cylinder head. Worst case? Broken ring, broken piston, or badly scored block from bad rings or even a wrist pin spiral lock failure. I'm hoping for the head gasket failure. Please keep us informed.
Old 01-13-2014, 03:32 PM
Can I fix any of the worst case scenarios without pulling the block and having it re-bored? I can't afford that right now LOL
I will. I plan to do it this weekend.
Old 01-13-2014, 04:45 PM
Default No compression #8....
It sounds like your not far away from getting the head off, so I would do that and diagnose what the problem is at that point. Then we'll help you make a decision as to what to do. I think you can get the pan off without much of a hassle. #8 is at the back of the engine so proximity to the cross member is a plus if you have to work from the bottom end with the pan off. Pray for a bad head gasket. Ken
Old 01-14-2014, 12:31 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Big failures usually make a big noise. Feels like a head gasket from here, anything that would break a piston or a dropped valve would give a loud report.
Did you check for water in oil? That's a head gasket. Yank both heads, freshen them up, and while you're at it, throw in a new timing set, curve the dizzy. She will run great again.
Hate to say it but my old kar knowledge says to yank the head, a stuck valve would not be out of the question either, or one that snapped a stem/tip and galled into place.
Old 01-18-2014, 05:12 PM
Any tips on getting the exhaust manifolds off??? The bolts to don't seem to be any particular size. The only thing I can get on their firm is a 14mm and I HIGHLY doubt that is the actual size. I've thrown every penetrating oil I have at it and can't budge them. Kroil usually works wonders for me, but not this time!
Old 01-18-2014, 05:17 PM
Deadhead's Avatar
Deadhead Deadhead is offline
There are probably other tools like this, but I have used Xtractor sockets to get those off. That and the acetone/ATF mixture. I think mine came from Lee Valley, but I am sure you can get them other places too.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 01-18-2014, 05:18 PM
Like this ???
http://www.sears.com/craftsman-10-pc...p-00952166000P
Old 01-19-2014, 07:25 PM
Heybuck's Avatar
Heybuck Heybuck is offline
Can't you just leave them ON and undo the pipes. Then lift the head complete with manifold off the engine.
When you have the heads on the work bench, you can attack them much more easily and the risk of skinned knuckles or broken fingers is greatly reduced.
Just my idea of an approach to the problem
Ian
To laugh at men of sense is the privilege of fools.
Old 01-20-2014, 02:31 AM
Deadhead's Avatar
Yeah, but the ones I have have MUCH finer splines on them, which has got to be better. You have to tap them on, and then they dig in further as you torque down on them to remove bolt.
-LBJ
66 Bonneville wagon
2005 GMC L-33
Old 01-20-2014, 02:17 PM
The bolts are 9/16", which is actually 14mm. My recommendations would be to pull the heads with the exhaust manifolds in place, and use rust remover and penetrating oil on the bolts. With the bolt heads clean, you can get a good 6 point impact socket on them and impact them off. Me, I'd let them soak for awhile, and maybe use some heat from a propane torch, too. Again, you may simply have a burnt exhaust valve. Not a big deal to fix.
Jeff
Old 01-20-2014, 03:58 PM
Ian
I have the exact same problem underneath. I think its going to be a pain either way
