Old 01-22-2014, 12:48 PM
cheese country GP's Avatar
cheese country GP cheese country GP is offline
Question Anti-freeze
Here's a question to ponder with our car's. How often should anti-freeze be changed? In years past it was recommended to change every 2-3 years using the old green stuff. I still use that style. What should be done to maintain good quality freeze & anti-corrosion protection?
Old 01-22-2014, 02:44 PM
jdh421's Avatar
jdh421 jdh421 is offline
Change the Antifreeze every 2-3 years. use a tester to make sure mix is capable of handling -20. Long life antifreeze is not necessary, unless you want to use it (more $$)
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 01-22-2014, 03:25 PM
I run the green and change it every water pump / teardown or hundred thousand mile mark whichever comes first.
former." --Albert Einstein
- Winston Churchill
Old 01-22-2014, 04:58 PM
Engine-Ear's Avatar
Wow, 100,000 miles?!
As much as these cars sit (well, not NIXON's evidently!!), if you have the time and the budget, consider a full flush (including removing the block plugs) and new mixed fluid (the green stuff) every 3 years. ...cheap insurance in my book
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 01-24-2014, 10:25 PM
Matt I buy them to drive them you KNOW that. The green antifreeze is a LOT better stuff than the extended life stuff.
Mike
- Winston Churchill
Old 03-03-2014, 10:23 PM
Engine-Ear's Avatar
Cool CheeseCountryGP addendum...
All: To add to CCGP's post, this attachment is pretty interesting...
Stay warm (and keep cool)...
...OK, well the attachment in PDF is useful. Maybe not as a 60kB jpg... email me if you want a copy of the article: made_in_milwaukee @ yahoo . com (remove spaces between the @ and . )
Last edited by Engine-Ear; 03-03-2014 at 10:35 PM. Reason: the file size limits are outdated!! Grrr.
Old 03-03-2014, 11:40 PM
poncho in a can poncho in a can is offline
...Evans waterless coolant....good forever....a bit pricey but........
