Old 01-26-2014, 01:36 PM
jim larson jim larson is offline
Default Shop relaced rear tube yoke on driveshaft. Problem?
I had the driveshaft balanced and u-joints replaced at a driveshaft shop. They also replaced the rear tube yoke. This was up in St. Paul. I wonder if they might have cut off driveshaft yoke at the weld of the old one or just ground down the weld to remove the tube yoke. I hate to bug them. Anyone know the process they would use? If they just cut it off, the driveshaft is about 5/16" shorter, will that cause a problem? Thanks.
Old 01-26-2014, 03:51 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Jim- to find out which procedure they used, you will most likely have to ask them. I wouldn't think they would look at it as bugging them. You paid for a service which should cover an explanation of how they accomplished the task.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 01-30-2014, 07:58 AM
chrisp chrisp is offline
Just look @ your front yoke - trans , if shaft is shorter you will see it .
Old 01-31-2014, 09:40 AM
I called and yes they said I lost about 1/4" . They said that should not be a problem; but I wish they had told me that they cut the end when replacing the rear tube yoke.
Old 01-31-2014, 09:44 AM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
What is the issue here?
Old 01-31-2014, 01:56 PM
GT182's Avatar
GT182 GT182 is offline
It's a silly millimeter shorter. Just pickin on ya Jim.
If it fits ok and there's not a lot of end play or vibration, it will work fine.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
The Following User Says Thank You to GT182 For This Useful Post:
Old 02-05-2014, 02:45 AM
lust4speed's Avatar
Horseshoes and driveshaft length - close is okay. You will have more spline in the trans than someone that raised the rear of their car up a few inches. This is a pretty forgiving area.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 02-06-2014, 08:40 AM
The trans. seal wear mark from prior to being cut should show on the yoke how much shorter the shaft is now .
Old 02-06-2014, 09:39 AM
1966geeto 1966geeto is offline
How much do you have that is going past the seal pull the shaft and look at the seal ring on the yolk should give you an idea where its riding 1/4 inch will not make any diff also will not affect balance they have to cut some material to get a straight weld I used to work for a driveline co was common practice to cut end to square it off for a straight weld.
