Old 01-27-2014, 10:27 PM
3fastgtos 3fastgtos is offline
Default 8.2 posi needed
Does anyone have a posi for 3.07 gears for a '67 Firebird?
Steve
Old 01-28-2014, 12:15 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
I'd go with a new BOP (not the chevy version) Eaton 8.2 posi as it's rebuildable. The old OEM cone style posi wears out over time and can't be rebuilt.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 01-28-2014, 02:13 AM
I'll check with them, hopefully they make one for that gear.
Thanks, SD
Old 01-28-2014, 11:25 AM
The posi carrier you need is the early 8.2 Pontiac mid ratio. Mid ratio is 2.93-3.08-3.23. Both Auburn & Eaton have produced a carrier for the early ('64-69) Pontiac 8.2 10 bolt.
Have pieced out quite a few 3.23 Safe-T-Track rears, & am currently out of used Safe-T-Track carriers, or would offer you one. Starting in late '69 (late '69 Birds), the Pontiac 8.2 10 bolt's ring gear bolt holes were opened up & along with the matching carriers accept 1/16" thicker lh thread ring gear bolts. Using a '70-72 Pontiac 8.2 10 bolt Safe-T-Track carrier with early Pontiac 8.2 gears, will need to make ten small bushings from thin wall brass tubing.
