Old 01-27-2014, 11:03 PM
38932's Avatar
38932 38932 is offline
Default Dash Harness
Is the '69 dash harness same as '70? I need one for my '69 GTO and found a very nice '70.
Old 01-28-2014, 09:16 PM
gto4evr gto4evr is offline
Yes, they'd be the same - but check the pinout on the speedo connector, there are two wires that switch positions with each other depending on whether the car is equipped with rally gauges or not. the wires for the gas gauge and alt feeds are the two wires. (so if your car's got idiot lights, and the 70 harness came out of a car with idiot lights, then your fine, but if one had lights and the other one had gauges then you need to swap the wires accordingly)
Old 01-28-2014, 11:58 PM
38932's Avatar
The 70 harnes did not have guages and my car has them so thanks for the info. It appears I am missing the intermediate harness between the tape strip trunk harness and the dash harness.
