Old 01-28-2014, 02:19 PM
scld1354's Avatar
scld1354 scld1354 is offline
Default 65 an 66 door interchangeability? Need to know real quick!!!!
I think the answer is yes, but I need to know if the driver door form a 65 gp will interchange with a driver door from a 66 gp? Same with the pass door....
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 01-28-2014, 03:01 PM
jdh421's Avatar
jdh421 jdh421 is offline
Yes. They are the same. 65 and66 have different mouldings so trim holes will need patched and redrilled.
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 01-28-2014, 11:29 PM
scld1354's Avatar
Thanks for the quick reply. I picked up a nice pass door shell from a 66 gp today. The car also had a nice pass quarter. I might go back and have them cut it our for me...
Old 01-29-2014, 02:23 AM
Heybuck's Avatar
Heybuck Heybuck is offline
Question Are they the same????
I don't want to contradict here but I'm not so sure they are EXACTLY the same?
I have a '65 Parisienne Convertible and a '66GP and I have noticed that there are minor differences in how the glass runners fit and I think something about the lock is slightly different.
I have no doubt at all that the doors will bolt straight onto the car but (maybe) you might need to use the glass runners and lock out of the '66 door.
Others might agree or disagree with this? I'll be interested to know for sure
Ian
To laugh at men of sense is the privilege of fools.
Old 01-29-2014, 02:32 AM
scld1354's Avatar
I wouldn't be surprised if the Parisienne was different from a Grand Prix, not because of the different years, but because I thought the Parisienne was chalk full o Chevy parts...
Either way, I guess I'll find out.
Old 01-29-2014, 03:44 AM
Heybuck's Avatar
Yeah, that crossed my mind after I typed the previous reply. If you look at a '65 or '66 front fender,and compare them between a Parisienne and a Catalina/Bonneville/GP etc, you would think they are the same. Well, the outer skin is the same but the welded in sections are different. Just small subtle differences but I can assure you, they are NOT directly interchangeable. They won't bolt up right because essentially they were adapting Pontiac parts to fit a Chev Radiator support panel. And the inner guards are different too
But on a door, I can't see why they would have changed things. I stress I'm only saying all this from memory but if I recall correctly I think the '65 door was slightly more complicated in how things go together. Remember that '65 was the first year of curved side glass so maybe later on for '66 they had worked out how to make it simpler. (Read cheaper).
Anyway, when you get the doors, it would be interesting to see if they are the same or have minor differences. That is apart from the holes which of course are different because of the side trim.
Ian
Old 01-30-2014, 03:41 PM
It seems to me that I remember a hinge fit difference at least on the 2 dr htps.
former." --Albert Einstein
- Winston Churchill
The Following User Says Thank You to mike nixon For This Useful Post:
Old 02-08-2014, 10:39 AM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default 65 66 door
i have in my 65 car an 66 RH door and the door is in the edge to the fender a little bit more wide than 65!!!
Here`s a pic if you see what i mean ..i adjusted already as close as possible ..it`S okay but i know it!
the inner door frame at this edge is different to 65 doors !! The outes skin is same but the part between the both door hinges area is more wide pressing the door skin at teh outer door edge out like 65 doors are .. if you need i will make some more pics from inner side
Rest is 100% same!
Name:	65 66 door.jpg
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 02-08-2014, 10:45 AM
Default 65 66 door
from side 100% same
Name:	Fotos Parisienne 2013 048.jpg
ID:	352217   Click image for larger version
Name:	Fotos Parisienne 2013 019.jpg
Old 02-08-2014, 10:49 AM
Default 65 / 66 door
sorry, but let me say no!! the 65 Catalina, Bonneville, GP, canadian Parisienne door 2door outer shelfs are 100% same but
66 has another inner frame in the shelf that bend the skin a little more out to the front fender, because the 66 front fender is a different one as 65!
compare your old and new door at the inner side to front fender area and you will see what i mean ...
Old 02-10-2014, 05:04 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
I've got a 65 GP door in Vegas if the 66 doesn't work out.
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 02-10-2014, 05:06 PM
scld1354's Avatar
I'm hoping to get the doors swapped within the next 10 days or so. I'll post on any problem I encounter.
Old 02-22-2014, 10:29 PM
scld1354's Avatar
I'm never going to find out if there are any differences. I went back to the yard where I got the door and took a closer look at the Grand Prix I took it from. Someone wrote "66 Grand Prix" on the quarter, but the door and cowl tags show it's a '65. My lucky day???
