Old 01-30-2014, 02:50 PM
Transporter Transporter is offline
Default 4 cyl. with conventional drive train?
Anyone on here running this combo, I realize that most times the swing axle is replaced it is because of going to a V8.
But on the coupe I am having done I am at the stage were the front floorboards are going to be welded in.
I would like to keep the car a 4 cyl, but I will be upgrading brakes all around, and just trying to decide on putting a tunnel and 4 speed in it, (it's already a stick car).
Thoughts welcome, convince me one way or another!
thanks
Stan
Old 01-30-2014, 07:40 PM
blueghoast's Avatar
I had thought about doing that with my wagon
and using a try angulated 4-link but I'm having
to much fun driving it so I don't have the time. LOL
Maybe in the future I might but for now I'm gona
drive it the way it is.
GT.
Old 01-30-2014, 08:53 PM
tom s tom s is offline
Seems a lot of work for a rear end that will hold up fine with the 4cyc?Tom
Old 01-30-2014, 08:56 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
It's a little work making a starter mount. Use a spacer plate to fit a later model trans and consider the difference in the crank register.
Old 01-31-2014, 12:43 AM
mechanickeith's Avatar
I am gathering parts to do a 4 cyl with a 200R with lockup & a 3.54 posi diff. Oh,, the 4 cyl is going to be a draw through turbo. About 5 lbs boost to start.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 01-31-2014, 07:40 AM
GaryK's Avatar
GaryK GaryK is offline
Hey Stan,
You saw my friends unfinshed wagon in Norwalk, he is running the 4 cyl tri-power with a 4 speed and a studebaker rear. If you need any info on this, give me a call and I will give you his number. He is not a computer guy.
Gary
The Following User Says Thank You to GaryK For This Useful Post:
Old 01-31-2014, 10:56 AM
Yeah Tom, I am with you that the rear will hold up fine to the power level of the four. I guess I was just thinking that I would really like disc's at all four corners, and an extra gear in the tranny.
The front disc's are of course easy, but Gary K and I had looked at the possibility of putting disc's on the rear axle, I'm sure it could be done, but probably more work/cost than it would be worth.
Also, if this is to be a "drivers" car, IOW, long distances, I think I might feel better with a conventional rear in back.
Again, appreciate all the comments, I'm just undecided on my direction, and if I am going to go conventional, I don't want to cut the floor out of a finished car, so I would have to do it soon.
Thanks Stan
Old 01-31-2014, 11:02 AM
Doug Doug is offline
Question Studebaker springs?
Originally Posted by GaryK View Post
Hey Stan,
Gary
As I recall, that wagon's rear end sat on leaf springs and the springs were "wrapped" with a metallic sheath. This is the first (and only) time I have seen springs wrapped that way.
I never got around to talking to the owner about this and I was wondering what the details are about the leaf springs.
Any info??
Old 01-31-2014, 02:27 PM
54nomore's Avatar
54nomore 54nomore is offline
My '54 Chieftain had springs like that. I had never seen that either.
Old 01-31-2014, 02:39 PM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
I think the only real issue on a long distance driver would be the rear wheel bearings. I just carry a spare axle on long trips. Front discs and a dual cylinder should be all the brake upgrades you'd need.
4spd/running gear sets are available.
Old 01-31-2014, 02:54 PM
63Banshee's Avatar
You guys are hitting on why I'm building my sister's wagon with a conv rear. I want maintenance to be easy for any shop she goes to.
The Following User Says Thank You to 63Banshee For This Useful Post:
Old 01-31-2014, 03:03 PM
As much as I wanted to have an original drive train car, I think I am leaning toward the conventional rear.
I also want to put Rallye 1's on the car, which of course necessitates a 4.75 BC, which I can easily attain with a conventional rear, and updated disc's on the front.
Other reasons would be,
Parts availability
Disc conversion all around
Adjustable suspension, (coil overs)
Makes a future V8 swap a day job.
Old 01-31-2014, 04:15 PM
63Banshee's Avatar
I'm of the opinion that there are few optioned 61-63s that should remain stock with only the rarest of 4cyl cars making that list. If my sister's wagon was an original 4bbl car I would have found her another one to modify.
Old 01-31-2014, 07:01 PM
Poncho-V's Avatar
Poncho-V Poncho-V is offline
Parts availability
Yeah, Stan , I'm going with Rally I's on my white car, so I am looking into what needs to be done to convert to 4.75 BC also. Front discs and a dual master cylinder are a given...not sure yet on the rear. Thinking of just having the drums re-drilled.
The Following User Says Thank You to Poncho-V For This Useful Post:
Old 02-02-2014, 07:44 PM
blueghoast's Avatar
Whys that Dave, Are the 4-barrel models kinda rare?
Mines a 4-barrel and power stirring sta-wagon.
Do I have me a gold mine. LOL Or just a daily.
GT.
Old 02-02-2014, 08:07 PM
63Banshee's Avatar
I think some cars deserve preservation. Especially those models that often don't survive restoration to original condition. It's possible your wagon would make that list for me. How about selling it to me and we'll find out --
Old 02-02-2014, 08:15 PM
blueghoast's Avatar
AW This ones a keeper I'm having to much fun with it.
Try and do a little work on it as often as I can.
Cars pretty dependable I put around 6000 miles
on it last summer. I hope to outdo that this summer.
GT.
Old 02-04-2014, 03:59 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
I seem to remember a guy put a Slant 4 in a 64. Had a turbo, maga horse power.
Old 02-04-2014, 07:48 PM
GaryK's Avatar
Any info??
I spoke with him today and he used "old time" Pontiac springs from the 40's. He said they used to wrap them in metal to keep them from coming apart. The rear is a 55 Studebaker V8 called a Dana 44, same bolt pattern as a Tempest. It even has the left hand threads on the driver side. He did this for the fit and to keep using the stock rims.
Gary
Old 02-04-2014, 07:53 PM
63Banshee's Avatar
Gary
Sucks I missed this car. That was a bad couple weeks for me. Will he be back this year?
