Old 02-15-2014, 12:07 AM
transam1972 transam1972 is offline
Default 1972 TRANS AM RALLY II RIMS
Name:	72 RALLY II.jpg
ID:	353078I admit to being out of touch with parts values but would any one care to speculate on the value of these 4 original NOV.71 build car..in an earlier thread I did confirm the rim number and dates..and yes they would need to be blasted and painted, trim rings & center caps replaced... thanks!!!
Old 02-15-2014, 08:05 AM
Judge273's Avatar
Judge273 Judge273 is offline
Not sure what the dates are on rims? All matching set brings most for those.
Mike/Illinois
Old 02-15-2014, 08:23 AM
Mezzo's Avatar
Mezzo Mezzo is offline
What condition are the lug holes in? I need a couple of replacements as mine are worn out. I may be interested in the set.
Old 02-15-2014, 08:35 AM
FunctionalShaker FunctionalShaker is offline
Generally you're looking at $400 - $500 per rim, no major damage, unrestored. You'll pay closer to the top end when buying a matched set.
Mezzo, your rims can probably be repaired for less than it would cost to replace them.
The Following 3 Users Say Thank You to FunctionalShaker For This Useful Post:
Old 02-15-2014, 09:19 AM
Norwood's Avatar
Norwood Norwood is offline
Agree 100%
Old 02-15-2014, 10:10 AM
Mezzo's Avatar
Can you guys recommend any one to repairs rims? I have a local wheel shop in Highland Park, IL that I may visit today to get an idea of what they can do.
Old 02-15-2014, 02:49 PM
2manyT/A'S's Avatar
Originally Posted by transam1972 View Post
Attachment 353078I admit to being out of touch with parts values but would any one care to speculate on the value of these 4 original NOV.71 build car..in an earlier thread I did confirm the rim number and dates..and yes they would need to be blasted and painted, trim rings & center caps replaced... thanks!!!
Can you link to thread where pics/codes are posted....or repost?
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
Old 02-15-2014, 04:14 PM
Default 1972 RALLY II
these are some detail shots of the rim..the worst rust kinda rubs off..others are better than the worst..note the GM sticker...even though you can not see it...that has to add extra value!!!!Click image for larger version
Name:	inner detail.jpg
Name:	inner rim detail.jpg
Name:	lug hole detail.jpg
Name:	wheel rim sticker.jpg
The Following User Says Thank You to transam1972 For This Useful Post:
Old 02-15-2014, 04:26 PM
Default RALLY 2
Name:	RALLY II BACKSIDE.jpg
Name:	STAMP DETAIL.jpg
Name:	ORIGINAL RALLY 2 & TIRE.jpg
Name:	RIM DETAIL.jpg
Old 02-15-2014, 04:47 PM
Name:	STAMP DETAIL 2.jpg
Name:	STAMPING DETAIL.jpg
Name:	PANEL REPLACEMENT.jpg
Name:	air extracter.jpg
Old 02-15-2014, 06:41 PM
Default RALLY II PAINT JOB
I always liked how the early Rally IIs were painted...I do not know what year they changed but my 1976 T/A had just the spokes sprayed...no fine masking at the edges and dull trim rings...little things like that are noticeable...were the early and late Rally 2 using the same colour grey insert, or did that change??...when did they get cheap with the paint operations???
Old 02-15-2014, 06:54 PM
2manyT/A'S's Avatar
73 was first year for rounded trim rings.........I'm thinking 76 for the cheapie paint jobs....
Correct color for Rally II's is REALLY subjective......
At your next Pontiac car show....start looking at Rally wheels....there will be a dozen restored GTO's and Firebirds with "correct" color Rally II's and no two will be the exact same color....
Old 02-15-2014, 07:00 PM
2manyT/A'S's Avatar
these are some detail shots of the rim..the worst rust kinda rubs off..others are better than the worst..note the GM sticker...even though you can not see it...that has to add extra value!!!!Attachment 353139
Attachment 353140
Attachment 353141
Attachment 353142
Attachment 353143
So these are a matched set of four 10 25 KR's?
Old 02-15-2014, 07:14 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
They can't be all the same. The outer hoop in the one picture was assembled in '72.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 02-15-2014, 07:24 PM
2manyT/A'S's Avatar
I'm thinking that the one with the GM p/n tag is a Service Replacement part rather than assembly line installed?
The Following 2 Users Say Thank You to 2manyT/A'S For This Useful Post:
Old 02-15-2014, 09:53 PM
Default SR T/A
I did say the owners husband worked at the dealer and the car was maintained there...I will post the $5K receipt she gave me...dated Sept 11, 1985 (weird?)...says something like 1972 TRANS AM and trunkfull of parts!!!...all N.O.S. stuff...the best was a new 1972 H.O.intake manifold, choke,throttle cable,parking lenses(amber)console & lid,etc.!!...anyway you are probably right about the rim...I have the Service Replacement TRANS AM!!!!..I will have to check every rim..but I am certain that was the only oddball...I thought it strange with the sticker but cool how it is still on!!!...I did not save the photo(can retake it) but early on in my thread(page #1) there is a photo I took of one of the front springs with a tag still on it..I cannot read what it says but is that normal?...did springs have tags for the assembly line workers??
Old 02-15-2014, 10:10 PM
Sometimes you'll find the parts number label, especially on spare wheel rims since they were hardly used and many times still have the original tires.
I am able to repair wallowed out lug holes but am currently busy with a number of customer's rally wheels.
The Following User Says Thank You to FunctionalShaker For This Useful Post:
Old 02-15-2014, 10:39 PM
Default SPARE
my car did not come with a spare...but I will check that rim with the tag more closely as someone says it has a date of 1972...car was built NOV. 71 so most likely a SR...what type of spare would my car have come with??..on the other hand I got the car so long ago if it had a spare on a plain rim I may have discarded it to make room..on the other hand all the spare parts were in the trunk so I really do not remember..it does have the jack that is in very nice shape and a blue painted base...all of the jack mounting hardware is welded to the inside of the trunk so is that not a way to tell...no space saver spare option on the P.H.S...now I will have to look for jack part numbers...more Indiana Jones research!!!..thanks everyone!!!...my lug holes are fine, I think MEZZO has the walled out holes?!!...actually I got a real nice set of Honeycomb 15X7 from P.Y. member EDVISME that I prefer over the RALLY 2s..I believe she did not go for Honeycombs for fear of them being stolen..Bayonne & Jersey City N.J. was filled with the hood even 40 + years ago!!!
Old 02-15-2014, 11:46 PM
2manyT/A'S's Avatar
According to the 1972 Pontiac Selling Facts and Accessorizer,dated Aug 31/71......
Trans ams came standard with 15" Rally II's and white letter tires....
As I recall,Honeycombs were a no cost option....as there is no price given for them on Trans ams....
Your spare should have matched what was on the rest of the car,as I understand it....
N65 Spacesaver tire was listed as a $15.30 option but states that it was NOT available with Rally II or Honeycomb wheels........
SO....anybody out there have N65 listed on their 72 Trans am PHS or build sheet?
Old 02-16-2014, 12:11 AM
When I saw the pic of the service part sticker was betting a 2/28/72 or a 3/35/72. Have numerous KR's with those dates that were sold over the counter. Nothing wrong with them, one I"m using as the paint match wheel. The 2/28's completed my date matching set of 5.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
