Old 02-18-2014, 02:15 PM
Default seat belt details...
This may sound off the deep end but...
What is the correct anchoring pattern of seat belts (rear or center front)?
Every untouched car, by memory, I have worked on had the following patterns:
1... date tags always face down
2...buckle side (female) always inboard
3...center seat (front and rear) are always bolted under (directly on floor pan) the out board belts
4...buckle (female) side of center seats is on passenger side
I find the last one counter intuitive since it would be better for the driver (of a bench seat car) to not have two buckles (usually adjusted to different lengths) together. I reverse it on my bench cars for that reason.
Has anyone seen the same pattern in untouched cars? or have you seen otherwise?
Sounds like a silly detail but I guess the rear center belts should be the right way for judging...no?
Even more nutty... which way should the rear ashtray cans be... extinguisher inboard or outboard?
Old 02-21-2014, 11:50 PM
MCronkGTO MCronkGTO is offline
What I remember about the ashtrays was the extinguisher inboard or closest to you.
Mark C
Old 02-25-2014, 09:13 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
John,
Here are a few 68 belt shots, both are Baltimore.
GTO
ID:	354524 Click image for larger version
LeMans
ID:	354527 Click image for larger version
Dave
68 GTO
68 GTO Convertible
68 LeMans
68 LeMans Convertible
68 Tempest Convertible
79 Firebird
