Old 02-24-2014, 02:13 AM
6d7gto 6d7gto is offline
Default Which epoxy primer to use over bare metal?
The car will be completely blasted to bare metal this spring then primed and left in primer for a year or more. Heard horror stories about certain primers coming off in sheets. Would like to go with red oxide color if possible.
Old 02-24-2014, 12:32 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
PPG dp epoxy or SPI epoxy is what I would go with.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 02-24-2014, 05:43 PM
Mark O Mark O is offline
PPG DP 50
Old 02-24-2014, 07:10 PM
carcrazy carcrazy is offline
Another vote for PPG DP. However you will be outside the recoat and have to put another coat in the future. I would probably use DP and then follow up with K-36 or 38 (high build).
Old 02-24-2014, 08:01 PM
400 4spd.'s Avatar
DPLF 74 is close to a red oxide color.
ID:	354333   Click image for larger version
Old 02-24-2014, 08:19 PM
Birdguy's Avatar
Birdguy Birdguy is offline
X2 on that. Doing it that way enabled me to work on other things without about having to sand and re-spray the DP and worry about adhesion.
Old 02-24-2014, 08:49 PM
lsp lsp is offline
EPOXY PRIMER... WOULD USE BLACK JUST CAUSE WHEN YOU DO BODY WORK ON IT YOU WILL SEE ALL THE DENTS ...
Old 02-24-2014, 08:51 PM
68 Firebird Brian's Avatar
68 Firebird Brian 68 Firebird Brian is offline
Are people using the DPLV 2.1 VOC epoxy primers? Is VOC standard working out?
68 Firebird 400 HO vert under construction
65 Catalina Wagon TriPower 389 under construction
Old 02-24-2014, 09:04 PM
paint guy paint guy is offline
Unless it is a requirement in your area, I wouldn't worry about a low VOC product. All you are doing is spending extra money to buy a primer thinned with exempt solvents which are typically more expensive. low VOC doesn't necessarily mean higher solids, just different solvents.
Old 03-02-2014, 01:08 AM
PaulatFast PaulatFast is offline
SPI
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 03-02-2014, 01:20 AM
Thanks folks!
Old 04-23-2014, 01:37 PM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Bringing this back up. Did you get your car blasted and primed?
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
Old 04-23-2014, 08:59 PM
gtome's Avatar
gtome gtome is offline
Id use SPI. It has a nice long working window and is easily sanded if you need too. Nice price too. Comes in black, red, and white.
Old 04-23-2014, 09:01 PM
GOAT WHORE's Avatar
And grey.
Old 04-23-2014, 09:08 PM
gtome's Avatar
I didnt know they had grey!
Also as a side note, if you reduce it (black), it drys to a nice sheen like suspention parts should be.
Old 04-24-2014, 10:57 AM
I'm taking the rest of the week off to blast the car. Thanks for asking. I'll let you know how it turns out. I'm using a dustless blaster DB150. Here's a link: http://dustlessblasting.com/
Old 04-24-2014, 11:10 AM
I'm confused now. I talked to a local body shop owner and he said not to use Epoxy primer but if I do, use an acid based etching primer first. He also said the epoxy primer is porous and will rust underneath. Is he correct or way off base?
Sounds like SPI is the best way to go at this point. I will give them a call. Plan to have it primed next week. Was going to do it this weekend but slight chance of rain. Figures.
Old 04-24-2014, 11:58 AM
propuckstopper propuckstopper is offline
Default Barry
Call Barry directly at SPI. Best tech support ever. He always answers the phone, and will give you all the correct information you need to succeed.
Old 04-24-2014, 01:54 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
SPI.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 04-24-2014, 02:54 PM
webfoot's Avatar
webfoot webfoot is offline
Pretty much the exact opposite of reality. Since you are blasting it will leave a nice texture for epoxy to stick to. Epoxy is not porous, high build is. Etch primer is old tech.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
