Old 04-03-2014, 01:19 AM
pb101's Avatar
pb101 pb101 is offline
Default 65 gto a/c wiring
Hello, does anyone know what the extra ground prong on the 7 prong ignition switch is for?
Thanks, Paul
Old 04-03-2014, 07:48 AM
Old Goat 67's Avatar
I'm going to guess that it's for the temp light?
ID:	359106   Click image for larger version
Old 04-04-2014, 02:00 AM
gtofreek's Avatar
gtofreek gtofreek is offline
I believe you're right about the temp light. IIRC, that ground post gets ground when the key is turned to start. This grounds out the temp light while the engine is cranking so you can see that the bulb works. Other lights[alt, oil] will come on with just the key on, engine off, but the temp light won't if the engine is not hot. So the only way to know if the bulb works is if something grounds it out while cranking. This is where the ground post on the ignition switch comes in.
This is easy to test with a 12 volt test light. Just hook the alligator clip of the test light to a 12 volt power source. Be sure the ignition switch is grounded. Then, with the key off, check that ground post on the switch to see if the test light lights up. It should not light up until, and only when, you turn the key to start. If this is how it works, then I would say it goes to the temp light.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-04-2014, 05:48 PM
pb101's Avatar
Thank you for the help and info.
Thanks, Paul
