Old 04-03-2014, 05:47 AM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Default Headlight help!
Well I finally got around to fitting relays to my lights on the 69 goat.
turned them on and only had the passenger side working well.
The drivers side was dim. so I unplugged relays and checked my new connections then tried lights again. and now all I have is LH side park light working.
I have checked and rechecked and still have no lights, what the hell happen?
What should I try?
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
Old 04-03-2014, 09:15 AM
Default Just guessing
Cause that's all you can do without being there.
IF you have the relays wired correctly........more than likely you mis-identified high/low/ground on the bulbs. Or at least have them stirred up.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 04-03-2014, 07:10 PM
Ozzmann's Avatar
I've got 3 lights working now, had to fix up a ground and pulled the sealed beams out to polish the brass connectors, which were dull. I think I have to redo another ground wire to get all 4 working.
Strange how just getting more juice to the lights upset the grounds.
Old 04-05-2014, 12:57 AM
salem1912 salem1912 is online now
Double check all your grounds.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
