Old 04-17-2014, 09:43 PM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
Default 70 GTO odd purple wire under dash
See attached picture. While trying to sort out the GEN and BRAKE idiot lights being on intermittently, I found this large gauge purple wire hanging under the dash. It routes over the top of the instrument cluster. I usually associate a purple wire with the ignition/starter circuit. Knowing my car will start in gear, clutch disengaged, do you think someone has bypassed the clutch safety switch? Is the wiring usually passed over the top of the I/C to the steering column?
1970 GTO
Originally 400, M20, Atoll Blue, PS, PDB, A/C
Now has 461 stroke, Keisler RS600 5 speed.
Just a fun driver
Old 04-18-2014, 06:55 AM
6t7gto's Avatar
6t7gto 6t7gto is offline
Are there wires connected to the clutch safety switch?
It is under the dash on the clutch linkage.
Old 04-19-2014, 08:51 AM
Nothing is connected to clutch switch so that must be it.
1970 GTO
Just a fun driver
Old 04-19-2014, 07:11 PM
jmt455's Avatar
jmt455 jmt455 is offline
Yes, those are the two wires that should be connected to the clutch safety switch.
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1924 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1941 Packard 120 coupe - Factory AC and OD.
1968 GTO, 428, THM400, 2.73 posi cruiser
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
