Old 04-18-2014, 06:53 PM
71SportRagtop's Avatar
71SportRagtop 71SportRagtop is offline
Default IT RUNS!!!
I got my new 428 fired up today!
The motor went in last weekend and I spent every night this week after work buttoning things up. 2 of my buddies came over this morning and we double and triple checked everything. Last night I put my battery charger on the battery to make sure it was fully charged.
Once we felt everything was kosher for start up, I filled the radiator with a mixture of coolant and distilled water. I already had the distributor set with the #1 piston at TDC. I pulled the distributor, and used my buddy's engine priming tool to prime the motor. I ran the engine primer for about 15-20 minutes with both valve covers off. My gauge read good oil pressure and when I saw oil flow in the valvetrain, I dropped the distributor back in and put the valve covers back on.
My buddy poured a little fresh gas into the carb and he grabbed the distributor to play with the timing and I turned the key. Nothing. It cranked for a second or two but didn't even stumble. I was so paranoid about cranking the motor on the new cam that for a split second I wasn't sure what to do but my buddy rotated the distributor slightly and poured a little more gas in and she started right up!
I ran the motor up to 2000 RPM and held it there for a while. Then I gradually took it up to 2200 then 2400 RPM and held it there for a while. I had my eyes glued to my oil pressure and water temp and everything held at good levels. I ran the motor at alternating RPM's above 2000 for about a half hour and other than my valve cover slightly leaking oil which dripped onto my headers and creating light smoke everything went flawlessly. We set the timing as best as we could not really knowing what it should be set at for a new motor with a hotter cam.
I shut the motor down and looked for leaks. Everything seemed OK but the temp crawled a little high due to the fan not running anymore so I allowed the motor to cool down for about 2 hours. Then I got a fan from my attic and plugged it in right in front of the car and pointed it at the radiator. I fired the motor up again and ran it for another half hour.
After another half hour, I shut the motor down again and cleaned everything up. I'm hoping that was enough to break in the cam properly.
I have a few minor bugs to work out. My Doug's headers sit a little differently than my Hooker headers and while I jury rigged up my exhaust to fire the motor up, I'm probably going to have to take the car to a muffler shop to be set up properly. Also my pulleys didn't line up correctly. My previous motor was a 68 400 and my 428 is a 69. My water pump pulley lines up perfectly with the PS pump but the alternator isn't even close. Again, I jury rigged it but I think I need a 69 or later water pump pulley.
Once I get everything fixed to the point where I am comfortable driving the car, I am going to take it to a friend who does performance work on the side and have him tune this motor properly to get max performance, then it will be cruising time!
Greg
68 Firebird Verdoro Green
428, 6X-4 heads, Comp XE284 cam
Muncie 4 speed
3:73 rear
Old 04-18-2014, 08:42 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Nice job! Sweet ride for sure. Best feeling in the world firing a new motor. I think you will be fine. The valve spring break in procedure calls for letting the motor cool completely down after break in. (if new) HFT?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
Old 04-18-2014, 09:59 PM
4dblnkldude's Avatar
Cool see you at the show june 13th.
Old 04-18-2014, 10:42 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Change the OAF pronto,and be sure to drop the oil while the oil is still smoking hot and thin as p!ss,please do not run the initial cam break-in oil for any length of time.
Next OAF can go a couple of hundred miles or so while dialing things in,but it too should be changed somewhat earlier than normal.
After that,use you can use your normal OAF change interval.
And be sure to cut the filters open and check for debris.
HTH
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 04-18-2014, 10:52 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Hope he's not a chevy guy.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 04-19-2014, 07:08 AM
max 93 max 93 is offline
It's a good feeling to fire a new engine isn't it? I just fired up a new engine this week too.
Old 04-19-2014, 07:36 AM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Such a great,nervous feeling!Glad it came alive with no problems for ya!congrates!
I am the Thread Killer!
Old 04-19-2014, 08:41 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Nice to read about another positive engine story. That car will work nice and congrats.
Old 04-19-2014, 08:46 AM
rohrt rohrt is offline
Congrats!
Old 04-19-2014, 09:25 AM
tpssonic's Avatar
tpssonic tpssonic is offline
Another great story. Congrats and enjoy!
Old 04-19-2014, 11:07 AM
Rownbike's Avatar
Rownbike Rownbike is offline
Glad to hear it! Good Luck with it and enjoy. I'm looking forward to seeing (and hearing it) at the PY Open House.
'69 Firebird original 400/4 speed
'72 Chevy Blazer 4X4 350 TPI/ 4 speed
Old 04-19-2014, 01:48 PM
LATECH's Avatar
LATECH LATECH is offline
Very glad to hear that things are turning out well for you. I know it was quite a struggle for a while there.
You'll forget all about it when you jump on it the first time though.
Enjoy and congratulations.
Old 04-19-2014, 05:06 PM
limejudge69's Avatar
Congrats dude! A 428 in a first gen Bird is a thing of beauty. With the 3.73 gears, that thing is going to be a handful.
Old 04-19-2014, 10:04 PM
HA HA you ain't kidding. I'm thinking that next winter's project may be to swap over to a set of 3:42 or 3:23 gears but I want to see how she runs with the 3:73's.
Greg
Muncie 4 speed
3:73 rear
Old 04-20-2014, 08:31 AM
ra96's Avatar
ra96 ra96 is offline
Congrats ill bet youll love it with the 3 73's anyway in 69 they used different snouts on the water pumps one is longer than the other and each had its own pully ( youll need to determine which pump you have ) or the offset needed on the pully let me know if you need a pully ive got a few
Old 04-20-2014, 09:33 AM
The Boss's Avatar
The Boss The Boss is offline
That's going to be a whole new animal now!
And go racin' in the street.
Old 04-21-2014, 06:55 PM
77 TRASHCAN's Avatar
Unless you HAVE to drive it every day, the 3.73's would be just fine, for me. Tell everyone, "It's just a cruiser..."
Glad for you that things are going good!!!
Shut it off
Shut it off
