Im changing over from a drivers side mounted speedometer cable to a passenger side for a 1969 GTO for a different 4-speed I got and was wondering if anyone can tell me where this cable is routed to install on passenger side?Any help would be much appreciated.thanks
1969 Matador Red GTO Judge,1999 Ram Air Trans Am,1998 Daytona Pace Car Grand Prix,1959 Bonneville,2004 GXP Bonneville. |
http://forums.maxperformanceinc.com/...+cable+routing
Search is you friend here. Down past tranny linkage, under tranny at bellhousing held with clips, then around in to trans. |
Do you know where I can get those mounting clips that bolt onto tranny bolts?Are there 2 or just one?Just wondering since I cant see in photo of routing if the clip up on the frame where it comes down from speedometer and firewall by the lock out rod has cable going staright back like mine for drivers side cable or is it turned towards passenger side.Im wondering if yours for passenger side has a 90 degree bend in it or is just straight and cable turns and goes under tranny?Thanks for your reply.Very helpful
