Old 04-25-2014, 07:03 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Default Cool Original
Love this one.... save for the moldings.....
.http://www.ebay.com/itm/Pontiac-Fire...US_Cars_Trucks
Old 04-25-2014, 08:20 PM
72projectbird's Avatar
I like everything except the moldings.
The side pipes are cool.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
blue71ta's Avatar
blue71ta blue71ta is offline
Thumbs up very cool
wow, what a great bird! It's too bad the body side moldings were screwed on.
I'm usually not a fan of the sidepipes either (unless it's a mid '60s Vette), but in this case, they look good. Love the old bias ply tires too.
Old 04-25-2014, 08:28 PM
The Boss's Avatar
The Boss The Boss is offline
I'd take it with the sidepipes - even leave them on.
Those moldings are a deal breaker for me.
And go racin' in the street.
Old 04-25-2014, 08:50 PM
tabob tabob is offline
I don't like body side moldings or that color, but I would drive it as is and enjoy every minute of it. Great car! I love survivors,especially original owner survivors.
72 TA 4 speed
76 TA auto father/son project
Old 04-25-2014, 08:56 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
I didn't think it could be that bad until I saw the molding. besides that, neat car and story.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 04-25-2014, 09:09 PM
Pepi's Avatar
Pepi Pepi is offline
Definitely the side moldings are horrible Like blue71ta mentioned, screwed on, that really sucks.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 04-25-2014, 09:57 PM
tom s tom s is offline
If anyone is interested in it I can check it out.Tom
Old 04-26-2014, 01:46 PM
bird72's Avatar
bird72 bird72 is offline
I might wonder if side moldings weren't STICK ON. They way they curved them! If so, hair dryer and OFF. It is hard to put a value on a car that clean and original. That only comes once. 15K is fair or maybe a bit more even on the bay. Pretty unique it appears to be a Formula wheel optioned Esprit.
caveat is IF moldings drilled, man around the wheels is mucho nasty holes. I bet stick on however. If drilled that bad, I wouldn't value more than 12K. **Investigation Needed**
72 Bird
Old 04-26-2014, 01:58 PM
The Boss's Avatar
Look like rivets in the pictures.
Old 04-26-2014, 04:33 PM
bossbirdta's Avatar
i think it looks like the worst of both worlds. they seem to be the stick on type and then were drilled and screwed/riveted on????? wonder what the thought process was on that. if only this car was just left alone, it would be a real good example of a true survivor car.....
Old 04-26-2014, 04:36 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Cool Car as is. Love the CB. Solid floors too!
BJ
Old 04-26-2014, 04:38 PM
Pepi's Avatar
Wonder if those were "dealer installed" moldings
Maybe they drilled and fastened them on so they would stick with the curvature.
Old 04-26-2014, 05:43 PM
FunctionalShaker FunctionalShaker is offline
It's unanimous, the side molding sucks. Talk about a hack job -- protect the car from dings, but drill holes in it.
Old 04-26-2014, 06:25 PM
Norwood's Avatar
Norwood Norwood is offline
I don't like side moldings on these cars and this one is as bad as I have ever seen. It has to be owner installed as no professional would do such a shoddy install. In my opinion the molding costs this car 4 to 5 thousand in value. Saved a chip or two but it has cost him in the end BIG TIME.
Old 04-26-2014, 08:46 PM
Transamric's Avatar
I totally agree.
Did anyone notice the Trim Tag build date code is 05E, but the Door Cert. label says June?
Old 04-26-2014, 09:41 PM
Trim Tag date is for the body build - on the Fisher side.
From time body has started to be welded together until finish paint can be 1 or 2 days.
Then it gets just about everything related to firewall back installed by Fisher after paint is baked.
Then it goes over to GM Assembly plant for everything else.
I'm not looking at a sticker to say positively - but pretty sure the MFG door sticker was applied by GM - on the GM side.
So if body build started on May 30 or May 31 - it might not hit GM side until after June has begun. Probably the scenario here.
Old 04-26-2014, 10:11 PM
Cool machine. Not sure how to best remove those moldings and repair what's underneath, but it needs to be done. Even if the paint ends up less than 100% original.
The side pipes gotta go, too. Car deserves to go back to original.
The brown interior is somewhat uncommon, although with that exterior color and V-Top, I think sandalwood would look better.
Old 04-26-2014, 11:19 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
I remember that old cheap molding that was sold back when this car was new. All the auto parts stores sold that crap in the customizing section of the store isles. If I remember right, it was a two part kind of thing. First you applied the actual chrome that had a sticky backing on it. You pre-shaped it to fit and cut it to length before you peeled off the backing and installed it. Then you popped in the rubber insert after it was cut to length. It was sticky back also. Regrettably, after the inserts wouldn't stay inside the chrome any more, they used little screws to hold in in. I think that's what happened here. Hopefu;ly the screws were to short to touch the body.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 04-27-2014, 04:12 AM
doublejointedyabbie's Avatar
doublejointedyabbie doublejointedyabbie is offline
I don't know if you guys have noticed, but you can see the back of the pop rivet on the drivers side showing through the door skin. Looking at the quarter panel pictures through the trunk area, you can actually see the back of the pop rivets. Still a beautiful car.
