Old 06-09-2014, 07:53 PM
71HOT/A 71HOT/A is offline
Default Roller rockers with stock valve covers
Like the title says. What have you guys used and any mods, say thick or double gaskets.
Old 06-09-2014, 07:58 PM
BILTIT's Avatar
BILTIT BILTIT is offline
BOP engineering sells 3/16-1/4" thick gaskets or valve cover spacers. Scroll to the bottom of the link.
http://www.bopengineering.com/beltdr..._topend4.shtml
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 06-09-2014, 08:07 PM
Joel Koontz Joel Koontz is offline
Not sure you need to do anything with the stock valve covers if all you are changing is the rockers.
Old 06-09-2014, 09:01 PM
tom s tom s is offline
I have had to use the thick gaskets with H&S rollers.Tom
Old 06-09-2014, 09:10 PM
goatless's Avatar
goatless goatless is offline
I have 1.6 Scorpion rockers under stock covers, just using the thick Butler gaskets.
In the past I had used the regular rubber gaskets when I didn't have a set of the thick ones, but used two of them glued together. That worked just fine, too.
1966 GTO
Old 06-09-2014, 09:27 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is online now
I used the thick gaskets and valve cover bolts for a ram air IV with H&S rockers.
Old 06-09-2014, 09:41 PM
Thanks guys. How about crower or comp steel roller rockers?
Old 06-09-2014, 10:28 PM
jww jww is offline
You may not have much of a clearance problem with the roller rockers but where I ran into problems was when I used poly locks. Those will be the tallest point in your valve train..
FWIW...not all poly locks are the same height, so you can shop around there some for the shortest ones that will work for you.
Just my $.02 ..............Jerry
Old 06-09-2014, 10:55 PM
trailwing's Avatar
trailwing trailwing is offline
I had to run spacers and go thru the Summit catalog to find just the right Polylocks. Are you going full roller? I'm not a huge cane of roller tip rockers.
1972 LeMans
"Individual results may vary..."
Old 06-10-2014, 01:42 AM
Nor-Cal 70T/A's Avatar
Nor-Cal 70T/A Nor-Cal 70T/A is offline
I went with the Crower Enduro stainless steel rollers and used the thicker gaskets, but my builder says they would have still cleared with the standard thickness.
Old 06-10-2014, 01:54 AM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
I like hearing that! I have the Enduro Stainless Roller Rockers for my new build and will be using the stock chrome valve covers.
Karl
Old 06-10-2014, 08:31 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Some of the later stock valve covers have the oil drippers built in that makes matters a little worse. Just a heads up for the later T/A guys. If you`re running stock A/C brackets, there`s only so much room to raise the covers.
Old 04-05-2019, 10:33 PM
gs462's Avatar
gs462 gs462 is offline
Hrmmmmmmmmmm
Shawn
1971 Formula #s match white/tan
1973 TA Brewster/white #s match
1972 Buick GS455 #s match 69k miles now a 470 stroker.
1986 Buick Ttype 66K miles many mods 10 sec street car.
2001 Mustang gt premium vert. Mamas car
Old 04-06-2019, 03:18 AM
Will Will is offline
With RAIV length valves achieving 1.7" installed height and HS 1.65 rockers all I needed was an extra thick cork gasket to clear with stock chrome covers (no drippers)
Old 04-06-2019, 03:59 AM
lust4speed's Avatar
It's a good idea to allow for gasket shrinkage also. I'm running Harland Sharp 1.65's with .630" lift with the 5/16" thick cork gaskets under my stock '67 valve covers on top of my 670 heads on the street car. Using rolled up aluminum foil across the rockers showed I had clearance, but not much. I figured if not the next snugging down of the cover then the second tightening was going to produce contact as I chased the shrinking gasket. Ended up running two thick gaskets for now. Plan on eventually purchasing the Crower stainless rockers and they will easily clear with one thick gasket.
Mick Batson
Old 04-06-2019, 07:07 AM
grivera's Avatar
grivera grivera is offline
I'm using Harland Sharp 1.5's with reproduction chrome valve covers (no oil drippers) and regular gaskets - no clearance issues.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
