Old 06-19-2014, 03:21 PM
David Holmberg's Avatar
Default The new CNC chamber E-heads
For those that didn't know, Edelbrock came out with a new CNC chamber round port for us to play with. It has a more modern heart shaped chamber that looks pretty nice. The rest of the head is the same, but now you can get a chamber that wasn't designed in the 60's. 61515 and 61525 are the numbers for the complete heads, 72 and 87cc.
These are going on my 474 and back in the car in a couple of weeks, so I'll be able to post updates about the timing needed and performance. I'll run these as "Out of the box" for the rest of the year, then send them off next spring for porting.
Anyone know the best way to get 4 years of dust off a car?
ID:	367330   Click image for larger version
Old 06-19-2014, 03:34 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Don't be concerned with the dust on the car, concern yourself with the rust on the driver.
Good luck with the car and getting back out.
Old 06-19-2014, 03:55 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Smile
Children!!!!
Less said,,,,,,,, Less mended.
Old 06-19-2014, 04:04 PM
LOL!
I lifted the car cover and it's not too bad.
Old 06-19-2014, 04:23 PM
Peckels Peckels is offline
Are those the 72 cc heads you have there
Old 06-19-2014, 04:27 PM
87cc
Old 06-19-2014, 04:51 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
David best way to get the dust off 100+ mph passes
Skip Fix
Old 06-19-2014, 05:24 PM
So I should let off before the 1/8th?
Old 06-19-2014, 05:38 PM
t money t money is offline
They have been available for a couple of year now but at something like a $100 more then the std rpm heads. They call them rpm cnc heads. I ask do you no if this is the new chamber on all them???
Old 06-19-2014, 05:41 PM
66bonne's Avatar
66bonne 66bonne is offline
Does E-Brock give you any flow numbers ? If I scratched my head enough maybe I could remember them. Do like that chamber shape.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 06-19-2014, 06:53 PM
The old, normal heads flow 275ish on the 87cc and 28x with the 72cc chambers.
Its been said that the new chambers will help the flow, but Edelbrock doesn't list a difference in numbers.
Tmoney, these are only on the CNC heads, the old chamber is still available, if someone would want it.
Old 06-19-2014, 08:27 PM
ponjohn's Avatar
ponjohn ponjohn is offline
David-
Are they new chambers on the original e-head?
Any differences in the port?
Are you going to flow them?
Old 06-19-2014, 08:52 PM
They are the same head with a CNC'd chamber added.
You can't tell from the outside if the head has the new chamber or not.
I'm not going to flow these at this point, but will before they are ported. Everyone that has seen them things they are much improved.
Old 06-19-2014, 09:32 PM
mchell's Avatar
mchell mchell is offline
looks familiar.....
Name:	2013-10-30 20.31.00.jpg
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 06-19-2014, 09:43 PM
john marcella john marcella is offline
It was better before.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 06-19-2014, 09:55 PM
Chad Speier Chad Speier is offline
Here's how I done that chamber.
Old 06-19-2014, 10:23 PM
Don't look like a Pontiac head to me.
John Marcella
[email protected]
ph. 248-259-6696
Old 06-19-2014, 11:54 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Congrats David! Good luck and have fun!!!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 06-20-2014, 12:29 AM
Mike, the KRE and both E heads (D and Round) have heart shaped chambers, but when compared side by side they are all different. Which one is better, that's a good question. I think the majority of these heads will be modified so it will just depend on the guy holding the grinder.
More than anything I think it just gives the porter a head start and a better base to start with.
Old 06-20-2014, 10:31 AM
Skip Fix's Avatar
And it probably gives the guys not wanting to weld then machine a better chamber than a generic one. Got to remember most of the E heads are on street/strip type machines not full tilt race motors.
Skip Fix
