What do you all use to tow your trailers?
I presently have a '96 F-250 with only 110K miles on it and I'm contemplating getting a newer vehicle in the next 3-6 months to tow my 28ft trailer. My car is not done yet, but I would like to be able to attend some events around Division 1 and also maybe as far west as Indy and as far south as Georgia or Florida. I'm not planning on getting rid of my truck. I've seen the RV's at the tracks and thought it might be something to look into, but I'm thinking that getting an RV might be excessive. I'm not a camper per say, so the RV would mostly be for towing the trailer to any event. This is basically a personal choice I understand, but I'm not sure of which way to go....a dually or an RV.
So the question (or poll ) at hand is what do you all use? |
I've owned two Duramax diesels and love them, plenty of power when towing a 28ft 10K lb trailer.
That said, my next true tow vehicle will be a motorhome. |
I use this.
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
That is a very sweet tow vehicle, unfortunately out of reach for most of us
Tim Corcoran |
that paid off. |
You didn't say what power train you had in your F-250?
I use my '96 Ford F-250 Xtra cab ....7.3 diesel. It's not a dually but does the job and then some. More than enough power and decent fuel mileage. Came with factory HD package. Tow a 26' trailer + carry a slide in truck camper with needed amenities. Doesn't require any hitch extension or toad wheel. The three S's and heat,stove, & AC. Use generator from trailer to power it . I did add of big turbo down pipe,cold air intake, & tuner. I set cruise control and motor on .. Too much upkeep($) on seldom used motor home for me personally.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
I have had 3 Duramax 2500 single wheel 4 door short box. Best ride out there for long distance in my opinion. 500,000 combined miles. People can argue the rest as far as power capacity ect... blah blah. They are all pretty good on that these days. Mine is still pre exhaust fliud 2010... serveral talk of added expense for maintenance, and failures with DEF (multi brands). Maybe the bugs are worked out on the new ones.
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 |
My dream is to have my restored 1965 Catalina wagon pull my enclosed car trailer with my restored 68 Firebird in the trailer. 389 /w Tri Power and a stock beefed up frame and hitch.
15' stock rims /w aluminum drums out front. Power brakes + trailer brakes. Should be good to go and a real looker on the road. I will be comin from a long distance to get to the Pontiac shows.
68 Firebird 400 HO vert under construction 65 Catalina Wagon TriPower 389 under construction |
I tow with a Class C Ford V-10 and we tow my wifes car with a 2000 Chevy 3/4 ton Van that i use for my mobile repair business.Second image is a video click on it to watch.
2003 Dodge 3/4 ton quad cab long bed diesel. Engine is around 375hp/750ft-lbs. Trans is 47RE with 48 guts, whiz bang this, triple disc that, and billet things. Truck pulls awesome. Was at 19,800 lbs last fall with 2 cars on a steel deck 2 car open trailer. Knocked down 13.5 mpg. Pretty happy.
P.O.S.I - It's not just a club...it's an addiction! |
Great setup Steve, not much you couldn't do with that van!
What size is your class C? 28-30? |
An Aventador.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
07 Dodge 3500 dually. 6.7 diesel.
I use a '97 Ford class A motorhome. It tows real well and is really nice to have at the track especially if staying overnight. It's not so good on gas mileage though but neither is my Chevy dually with a 454. If I had to do it over I would stay with the RV with a V-10 or try to find a cheap diesel pusher(if there is such a thing).
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Now that is handy at the race track.
I use a 72 3/4 GMC, 402 8 lug wheels and air, and 2012 F250.
Local I use a Duramax Dually crew cab 4x4 with a 100hp programmer, if it is more than a day race I use 32ft Thor Class C motorhome with a V10. Pulls a 24ft trailer decent. RV is nice to have...able to get out of the heat, place to fix decent food, and if you are hauling out of town...you get to stay with the car...not to mention you can just pull over in a rest area.
I hear people say how expensive a Motorhome is.....but when you see so many cars/trailers/rigs being stolen from tracks, hotels etc. its cheaper than replacing it all. My next set up will be a Renegade Toterhome hopefully by first of next year.
Mike, they're not much more than a diesel truck. Your plan is what I'm planning to do.
I tow with a 69 Catalina 2 dr hard top.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
