Old 06-23-2014, 10:40 AM
joe'sgto's Avatar
joe'sgto joe'sgto is offline
Default any body have a picture of 68 Gto Lemans Tempest power rear antenna
Does anybody have a picture of 68 GTO, Lemans or Tempest power rear antenna
I am looking for one so I want to make sure that I am buying the correct one. The car is a Hardtop. I know convertible are different.
or part number on it
thanks dave
Old 06-23-2014, 12:29 PM
7T-GOAT's Avatar
7T-GOAT 7T-GOAT is offline
http://www.ebay.com/itm/271317600769
That's a convertible antenna. Hardtop just slightly different top flange. 1968-1969 same antenna.
Old 06-23-2014, 05:03 PM
Simple Man's Avatar
WOW! That's some serious coin, for a used one.
be a simple...kinda man.
Old 06-24-2014, 11:35 AM
joe'sgto's Avatar
so this antenna is not correct
Old 06-24-2014, 07:08 PM
joe'sgto's Avatar
anybody. I think it should be a 2 wire connector at the motor
Old 06-24-2014, 07:45 PM
bkmont's Avatar
bkmont bkmont is offline
Dad-gum, wouldn't you know it.. That's one the parts missing from pile of parts.
Old 07-01-2014, 02:29 PM
Scott Thelander's Avatar
Default real 69 power antenna
pics of a 69
2 wires only
Scott
ID:	368761   Click image for larger version
ID:	368762   Click image for larger version
ID:	368763   Click image for larger version
Old 07-01-2014, 04:40 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
cool, I want your faceplate that has the notch for power antenna switch.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 07-01-2014, 08:10 PM
1968 convert.If it helps;
Name:	old pix found 135.jpg
ID:	368814   Click image for larger version
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 07-02-2014, 08:45 AM
That looks like a Ford antenna, they used the same supplier but the motor is reversed and they didn't use a separate lower bezel.
Old 07-02-2014, 11:52 PM
joe'sgto's Avatar
I was not home to look at the car. That's why I ask about the antenna I was looking at. I also thought it was wrong.
Still on the hunt
The worst thing about this is that I know my brother save the power antenna and I just cannot find it.
