1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 06-30-2014, 09:14 PM
firebird man firebird man is offline
Default rear end ratio
I would like to know the rear end gear ratio on 1991 firebird. thanks
Old 07-15-2014, 10:38 AM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
depends, what all does it have (engine, transmission)
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 07-22-2014, 12:50 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
1991 was the change over year for the location of the SPID label. Early production has it in the center console glove box, late production will have it on the lockable storage compartment lid on the left hand side of the trunk area.
It will have the RPO codes for all installed parts and options. Axle ratio code will be in the Gxx series. That will tell you what ratio the car was built with.
