Old 07-04-2014, 05:51 PM
INFILTRATOR's Avatar
INFILTRATOR INFILTRATOR is offline
Default HOUSTON TX area pontiac engine builders
Someone know of a company thats builds pontiac motors in houston area?? thanks
1970 T/A clone
Old 07-04-2014, 06:01 PM
tom s tom s is offline
How about Abilene?Jim Robertson,he is on this board.Tom
Old 07-04-2014, 07:53 PM
Does he have a shop or is this out of his garage? Just asking.
1970 T/A clone
Old 07-04-2014, 08:07 PM
Definitely not just a guy putting engines together in his garage: http://www.racev8s.com/index.htm
Old 07-04-2014, 08:09 PM
forget it lol, its over 400 miles away. But thanks for the info. Im trying to see if there is anything local before i have to make a crazy trip anywhere.
1970 T/A clone
Old 07-04-2014, 08:36 PM
You might call and talk to Jim,you will not be disappointed.Know its a hike but engines dont get built overnight.He did my RA V heads.Tom
Old 07-04-2014, 11:33 PM
Lee's Avatar
Lee Lee is offline
What part of Houston? What sort of build?
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 07-04-2014, 11:42 PM
you got a pm!
1970 T/A clone
Old 07-06-2014, 07:56 AM
LPI's Avatar
LPI LPI is offline
Do a search fellow PY'r is Dan Barton he is in Houston. He knows his stuff.
Also USA Racing Engines on Dillon Street in Houston. Contact Chris or Bruce 713-645-4000.
Also PM skip fix as he lives on the west side of Houston and he knows a lot of engine builders down there.
Holy cow Tom that's a dirt road...
www.luhnperformance.com
Old 07-06-2014, 12:47 PM
moneypit's Avatar
moneypit moneypit is offline
You might call the guys over at Westside Performance and Machine. (713) 465-7996
They did all the machine work on my 462. I've been real happy with the results and the pricing was reasonable and the turn-around time was as well.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
Old 07-06-2014, 02:22 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Lots of choices here in Houston and lots of opinions on those choices
Dan Barton has left Westside and gone to Naiser racing still doing heads. They can do engine work there also-leaning towards race type motors(sheet metal intakes aluminum blocks all over the place(I did get them a Pontiac block for mock ups).
http://www.naiser-racing.com/
Westside has done some work for me,dynoed two motors there. G&G up in Tomball has done work for me for years Pontiac stock blocks and my IA, and my 409/470 final work. I know local Pontiac guys who have had issues with both, but others with good results.
USA racing is another some of the Texas Pontiac racers have used-the Clegg's(Super Stock racers) over in Victoria use them for their Pontiac motors but Nickens for the big corporate BBC style motor in John's car.
http://www.nickensracing.com/
Another shop down in Pearland some of the guys have used, as well as Faerman's on Pinemont.
Skip Fix
Old 07-06-2014, 03:16 PM
Alvin's Avatar
Alvin Alvin is offline
Try Lloyd & Craig @ Bellaire Auto Center: http://www.bellaireautocenter.com/bellaireauto_004.htm
Old 07-06-2014, 03:21 PM
David Holmberg's Avatar
Dan Barton and Jim Robertson really know their stuff!
Lee can also do a very good job for you.
Alvin, I didn't know that Lloyd did full builds, good to know.
Old 07-07-2014, 07:58 PM
cnhorn63 cnhorn63 is offline
Owens in Pearland??
Old 07-08-2014, 09:16 AM
Skip Fix's Avatar
Yea I think Owens is the one in Pearland.
Skip Fix
Old 07-08-2014, 11:55 PM
thanks everyone!!
1970 T/A clone
Old 07-11-2014, 10:34 AM
Larry Navarro's Avatar
Two thumbs up on Owens!!
Do not........DO NOT, use G&G in Tomball.
Old 07-11-2014, 01:04 PM
Skip Fix's Avatar
Larry is one of the ones that had issues with G&G,if you can't tell
Skip Fix
Old 07-14-2014, 08:00 AM
I helped Russell remove an engine that G&G had to rebuild twice because of poor workmanship.
My last and only engine that G&G did was not align-bored properly and resulted in my having to source and buy a replacement block along with another set of billet main caps.
Old 07-14-2014, 11:52 AM
OUCH, now that hurts.
1970 T/A clone
