Old 07-16-2014, 09:36 AM
heckinohio's Avatar
heckinohio heckinohio is offline
Default Upgrade water pumps....worth the $$$??
My wagons water pump has an unknown number of miles on it. Car sits a lot. I noticed a puddle some months ago........didnt heal up so I guess it is time to replace.
I see some up grade stuff available. This car has 43,000. I have owned it for 30 yrs, had 41,000 when I got it.......so it doesnt fall into the category of a regular cruiser. I did buy regular license plates this year & insurance. I intend to drive it. My physical ability is being compromised by my age, not good.
So, cheapy replacement from local auto parts or.........????
PJH
Old 07-16-2014, 12:26 PM
MescaBug's Avatar
MescaBug MescaBug is offline
Here is my answer to that same question in another thread:
http://forums.maxperformanceinc.com/...d.php?t=757417
Just get a good rebuilt Pontiac water pump. Should be good enough for your needs.
Old 07-16-2014, 01:06 PM
webfoot's Avatar
webfoot webfoot is offline
what I have learned by reading this forum is that 1. you need to get one which has the cast iron impeller, as opposed to some of them which have newer (yet apparently worse) stamped steel impellers. and 2. you need to check clearance between the impeller and the water pump plates. I believe there is a rather large thread in the heating & cooling section about this.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 07-17-2014, 12:53 AM
Koppster's Avatar
Koppster Koppster is offline
What webfoot said
I'd add that my reading led me to believe the only superior pump out there is built by Evans and I concluded that aluminum Flowkoolers probably weren't any better than stock style pumps with cast impellers
