Old 07-16-2014, 08:31 PM
dld's Avatar
dld dld is offline
Default inner fenders
need some help on my 65 inner fenders. The right side inner fender has what seems to be a factory punch out of three holes. What I would think were for mounting of washer fluid concentrate. This is a item of more than I expected I got a point off for at the GTOAA convention this year. Asking for you guys thoughts. Notice center hole is not round.
I did walk around and check out the cars and no other car had them. Also the washer fluid bracket does not match these holes . I did not want to drill more so just did not install what i have
I also got banged for sheet metal (engine area) paint among other things I will ask about later . thanks for help
ID:	370305   Click image for larger version
Old 07-16-2014, 08:48 PM
62 bv 62 bv is offline
what did they not like about your paint it looks great to me
Old 07-16-2014, 09:10 PM
dld's Avatar
dld dld is offline
No description of issue. just 1 point off
Thanks for that I needed it!
Hey car just was not its best. struggled to get it there. car was in paint touch up night before . Sure could have been cleaner. But I have the sheets and will FIX WHAT I NEED TO. with your help. I'm not a concours guy just want a concours car LOL
Old 07-16-2014, 09:11 PM
Option 382's Avatar
Option 382 Option 382 is offline
Yes those 3 holes do stand out. Are you asking if you thought that is where the optikleen bottle bracket would have been installed?
Old 07-16-2014, 09:14 PM
dld's Avatar
dld dld is offline
yes.
Old 07-16-2014, 09:27 PM
Option 382's Avatar
The optikleen bottle was a dealer installed option. That being said every dealer, mechanic, or car owner could have installed the bottle in different places on the car. I have heard later in life that the wheel well plugs slightly below your 3 mystery holes is where the bottle was supposed to be installed but since it was never a factory option the location could be installed via preference. So that might be a good place to hide those holes.
Old 07-16-2014, 09:38 PM
dld's Avatar
dld dld is offline
Thanks for comments. i was always under the same thought. but the puzzling thing to me is the center hole is not drilled. its a punch out. dealers would not have that ability.
a question for you. are your six cyl. battery tray close out plugs . that would be the two plug holes that you refer to are they rubber or plastic
Old 07-16-2014, 09:41 PM
dld's Avatar
dld dld is offline
this car has all the OE metal. dated fenders never apart
Old 07-16-2014, 09:46 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Those two hole plugs are plastic, not rubber. And I agree with Option 382. The Optikleen bottle was a dealer installed bottle and could have been installed anywhere. Of the dozens of 65's I've owned or been closely associated with I've never seen holes like that. And the judges could have thought your paint was just a tad dull. 60% gloss is glossier than the semi gloss paint that most places sell today. The original paint had an 'eggshell' gloss to it. It's pretty hard to duplicate.
Your engine compartment looks pretty damn good to me!
Old 07-16-2014, 10:01 PM
dld's Avatar
dld dld is offline
actually a little hard to judge gloss different light levels.
i do paint all day and did spray outs several times adding or lessening flatner until i got what i remember as correct. but was not quite correct i guess. hey i thought Scott T's car was to glossie. ( the 64 Ferrari getter ) .Jerry thanks for impute. Remember you saying you were a judge once .
one of the members here ( Bob Coleman)that had a 12th month bal. car told me he had rubber plugs in his fender wells as plugs. Do agree that the PON. cares have plastic but my car on disassembly had rubber.
Old 07-16-2014, 10:19 PM
John V. John V. is offline
The Optikleen bracket was a dealer thing.
This was so you could carry a spare bottle of fluid around with you, neatly mounted under the hood.
I actually always thought it was kinda a stupid idea. First, because it was a glass bottle, too likely to break.
But mostly because it depended on you remembering to put a full bottle back in the bracket after you used it. I know I would have rarely remembered to do that so would be just as likely to be caught without fluid as if I didn't have that accessory in the first place! Same reason I run out of propane for my grill even though I have 2 bottles.
At the end of the day, I think its primary purpose was a pure money maker for the dealers.
Separately, of course, there was the 2 spd wipers with washers option. Standard car got single spd wiper, optional was a 2 spd wiper (no washers), and the 2nd option was 2 spd wipers coupled to the washers.
In this case, you got a fluid bottle just like in a modern car with hoses routed to the spray nozzles. The bottle was mounted to the rad support, not the RH inner fender, IIRC.
Did your car get built with the 2 spd wiper with washer option?
Or did it come with the single spd std wiper?
In '65, there was a Dealer Accessory Package available to add washers to the single spd wiper.
Package p/n 984428.
I have no idea what the kit consisted of, I would have guessed it would have used the factory style washer bottle and mount, so doubt it would explain your odd holes, but worth knowing what your car got for wipers from the factory.
What is really strange to my eye is the hex shaped center hole. Least I think it is hex shaped. Not round anyway. Hard to imagine that being punched in the field.
But one thought comes to mind, possibly an aftermarket alarm system installation? Professionally installed, very possible they could have used a special hand punch to punch that shape hole for mounting of some component.
Might be helpful to see the whole inner fender to better understand the specific location of the holes, but I can't think of any factory option that would have required additional holes not seen on all inner fenders. Normally, the sheetmetal was punched to accommodate any possible option whether the car was to be equipped with that option or not. So even if you had some rare factory option, the holes for that option would show up on all cars.
Since that isn't the case with these holes, almost certain they were for some aftermarket thing.
Sorry to suggest bad news. But under hood looks great anyway as brody says.
Did they think the black was too shiny?
Old 07-17-2014, 06:13 AM
Jeff Hamlin's Avatar
The location looks like to would suggest the washer Fl concentrate/glass bottle.
However the brackets only used two screws
Even though it was a "Dealer" install it has been my observation that most are mounted in close proximity to washer jug.
Note; mine is almost on the same location of inner fender just on DS due to it being a 6cyl with Battery on PS.
You bay looks GREAT! Don't beat yourself up over the judging discrepancy. Years ago I lost points for "Shocks & Tires" but no one could clarify what or why. I entered a national judged show in hopes to gain better knowledge. I knew some items where not 100% but at the end of the day never received anything beyond a deduction. So now I avoid nationals and drive the hell out the car just as it was built to be.
Cheers.
Old 07-17-2014, 07:48 AM
dld's Avatar
dld dld is offline
Yes car was built with two speed/washer sys. That led me to think holes were factory. That and the octagon center hole that I thought would be hard to produce in field.
But with my investigation and you opinions thinking now on plan B
Jeff, like your idea. pretty much did that drive it like I stole it thing all my life. Thought it might be time to check out the subtle side. It is challenging just as expensive also.
ID:	370329   Click image for larger version
ID:	370330   Click image for larger version
Old 07-17-2014, 07:49 AM
Option 382's Avatar
Your optikleen brackets must be for later years application. I always thought the original ones were a 3 prong bracket and the reprodutions were 5 prong brackets like you have pictured, but it looks like yours is NOS. The one I have has 3 prongs.
Old 07-17-2014, 09:07 AM
8LUG 8LUG is offline
Great details, you're one of very few that use the correct label/with part number. Way to go! John
Old 07-17-2014, 10:08 AM
dld's Avatar
dld dld is offline
here are my water slides you asked for
Old 07-17-2014, 02:20 PM
Need to correct the typo on the decal, should say "or" equivalent , not "of".
Did you make your own water slide decals?
Seems like somebody proficient with graphics software, a digital image of a decent original, and water slide printer paper could generate an exact copy with the rounded corner black edge and original font on a good printer.
Or am I dreaming?
Old 07-17-2014, 02:33 PM
I'm out of my league here but was just wondering.....
I wonder if the judges thought that the color break line was too crisp at the top of the firewall. Yours looks better than the factory examples I've seen where the outside color was just kind of fogged into the black of the firewall and it was obvious they didn't mask or tape anything at that point.
I have no idea what judges look for or whether they would deduct points for something that looks 'too good'...?
I'll echo what the others have said...It looks great!
Old 07-17-2014, 03:08 PM
dld's Avatar
dld dld is offline
first attempt for me. But guidelines and i love this is profound . reads "Best day factory"
witch I interpret as to the line with no hard edge. but I do agree with you lots were very faint at top
Old 07-17-2014, 03:25 PM
dld's Avatar
dld dld is offline
J V check out 1st post. Damm you caught me. LOL
http://forums.maxperformanceinc.com/...ghlight=decals
