Old 07-24-2014, 11:07 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Default Anyone here with Parkinson's?
Is anyone on this board suffering from Parkinson's disease? I've had some symptoms for years that have gotten worse just recently that are very similar to Parkinson's. I have to hold on to a glass really tight and pay close attention in order not to spill it. No pain or any other problems, just lot's of muscle twitches. It's hard to type because I have to correct so many mistakes were my fingers just jump across the keyboard. Not a biggie, just an aggravation at this point.
I have an appointment with my GP next Monday morning, I'll see what he says.
Old 07-24-2014, 11:16 PM
Mother in-law had it for years. Shaking as you describe but that was it. She pass a few years back of heart failure.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 07-24-2014, 11:32 PM
60man's Avatar
60man 60man is offline
My Dad had it. His hand would twitch when he wasn't doing anything but would stop when he used it. It progressed to where it was shutting down his motor functions at times. I am told MS can cause tremors also. My hand shakes at times so hope I don't get it too.
Good luck. Hope all goes well for you.
ECM member.
MANDRA
Old 07-24-2014, 11:39 PM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Thumbs up
He's going to refer you to a neurologist. It's not necessarily Parkinson's. What you're describing could be an "intention tremor."
Good luck.
Old 07-24-2014, 11:40 PM
Bob Hall's Avatar
Bob Hall Bob Hall is offline
Might want to run tests for Huntington's as well.
1947 Ford Coupe
1972 Pontiac Luxury LeMans (Sold to Nephew)
1984 Chevrolet Monte Carlo SS
2003 Chevrolet Monte Carlo SS Jeff Gordon Edition
2017 Dodge Challenger SXT Black Top Edition
Old 07-25-2014, 06:58 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
My former mother-in-law and my uncle have it, terrible thing. Hope it's not what you suspect.
Mitch Kunath
Old 07-25-2014, 07:56 AM
Deadhead's Avatar
Deadhead Deadhead is offline
Know many older people (mid 70s) with tremors. First try a couple shots of scotch. Can abate them. Dr actually suggested prior to going on meds. Then there are medications. One friend took the meds for years but HATED the side effects. He had a hard time holding a fork or spoon prior. He eventually gradually reduced meds and quit them. Now tremors are less significant and he is happier without the meds. He is a big golfer.
Tremors far more common than Parkinsons. Good luck.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
Old 07-25-2014, 10:57 PM
Jerry H.'s Avatar
I definitely have some sort of tremors. But it would be hard to have scotch at 6am in the morning! Seems thats when they are the worse.
Old 07-26-2014, 06:43 PM
77 TRASHCAN's Avatar
My Dad has tremors, youngest brother also, Thankfully I do not. I have enough other health issues....
The tremors are not easy to deal with, but are livable.
Parkinson's can be dealt with, but is another whole different story. It progressively screws w/ your body, until you lose most of your motions, like walking .
One of my fellow Pontiac enthusiasts has the real Parkinson's Disease. He's had it for around 10 years, retired 3 years ago @ 64.
The only medication that has ever worked, is called L-doppa. It's been used for years. The problem is that the longer you use it, the less effective it is. He's a member here, but doesn't post. He's going in for an evaluation soon to potentially have a new technology type of surgery. I know little about it but he says sensors are implanted in your brain that stimulate it to lessen the effect of the disease. I'ts worked on many folks...He says he will be happy if it just helps a little. He's taken L-Doppa for so long, that it's effectiveness is really starting to drop off. I'm praying for the surgery to make a great difference in him!!!
The time table with which Parkinson's degrades your body is different for everyone. There's a point in which the disease has taken a massive toll on your body called "The Wall". When you hit the wall, you're bed ridden, essentially a veggie. Few make progress after the wall. I believe God can heal you, however, whenever, whatever!!!
Jerry, I hope your only problem, is from NOT having that scotch @ 6 A.M....
Shut it off
Shut it off
Old 07-26-2014, 09:05 PM
Jerry H.'s Avatar
I have two friends that have Parkinson's. One had a type of surgery on one side of his brain, and they are wanting to do it on the other. He's had it for about 15 years now, he can't work because of his tremors. I haven't seen him since the surgery so I don't know how much it has helped his tremors, but it has helped his speech. The other friend is a car guy and helped me on my 65. He had to go my 2:30 everyday because his meds would start to wear off. I haven't seen or talked to him, but his brother tells me that his has had that surgery and he is a ton better.
Old 07-27-2014, 08:25 AM
Half-Inch Stud's Avatar
My dad (82) has had the symptoms (and diagnosis) for about 6 years. i'm not at all convinced it's Parkinson; seems highly correlated to his nutrition//eating.
Eats well : clear thinking and talks well, moves well. Technically minded.
Eats poorly : stu stu stutters badly with fits&starts making speech uncomprehendable, twitchy hands, and cannot walk. Bad memory too.
If that is Parkinsons then there you go. Try nutrition that works.
Old 07-27-2014, 09:31 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Jerry H.
I do not know if you are on any other medications but I have heard that there is something called medication induced Parkinson's. My brother has been diagnosed with this and was put on Requip a couple of weeks ago. I will see him today and find out if it helped.
Old 07-27-2014, 11:29 AM
bankbook's Avatar
bankbook bankbook is offline
http://www.apdaparkinson.org
Excellent resource.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 07-27-2014, 08:05 PM
Jerry, glad to hear, will forward positive feedback.
Had not heard of the nutritional aspect. Proper nutrition I am sure would help. I know my buddy does eat pretty healthy. He physical health has been a slow, but unfortunate downward spiral, in last 8-10 years.
Shut it off
Shut it off
Old 07-27-2014, 08:46 PM
carcrazy carcrazy is offline
Low blood sugar??? Essential tremor???
Old 07-27-2014, 10:24 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
Good luck.
X2 My sister in law has had slight tremor for years but not Parkinsons.My father had Parkinsons.His hand tremors were only at certain times.His other traits were shuffling
his feet and stiffness as in not being able to turn his head to look behind him,and easily loosing his balance
Old 07-27-2014, 10:25 PM
Jerry H.'s Avatar
Originally Posted by ponchjoe View Post
Jerry H.
I am on a ton of different meds, but nothing has changed in a couple of years,
Old 07-27-2014, 10:32 PM
Blue '66's Avatar
I worked with a guy who was 70 years old the had tremors pretty bad,If he had to sign his name for something legal(loans ect)it had to be in the morning.His hand writing was not readable later in the day.
