Old 08-07-2014, 06:06 PM
DHVoorhees DHVoorhees is offline
Default Looking for 326 engine parts suppliers
I'm currently rebuilding a 1966 LeMans 326 engine.
I think it's all stock with no internal engine mods.
I'm looking for a parts supplier for new parts if anyone can help it would be greatly appreciated:
1)Stock Ring set
2)Stock Main Bearings
3)Stock Connecting Rod bearings
4)Main seals
Thanks!!
Old 08-07-2014, 06:51 PM
Bearings and seals you should be able to get from your local parts store. They would be the same as a 400 or 389. They might be able to get the rings also. If not try Egge Machine. They sell pistons for about everything so they might have rings also.
Old 08-08-2014, 01:35 AM
mechanickeith's Avatar
All those items should be available from any decent NAPA. If not, as stated www.egge.com should have all the parts.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 08-09-2014, 11:48 AM
Mr. P-Body Mr. P-Body is offline
Sealed Power "rering" kits contain all the aforementioned parts. Any Federal Mogul outlet can supply them. Use the BOP or GraphTite rear main seal.
Jim
Old 08-09-2014, 04:02 PM
ponyakr's Avatar
ponyakr ponyakr is offline
Default 326 Head Gaskets ?
Don't know if anybody else still makes head gaskets for a 326 or not. I suppose most just use the Fel-Pros with the 4.3 bore. But Cometic makes a real good gasket with a smaller bore size for the 326.
But they ain't cheap.
http://www.jegs.com/i/Cometic-Gasket...ductId=1288713
Old 08-11-2014, 07:32 PM
Nope, the "small bore" gaskets are all gone. We looked for them everywhere about 8 years ago. Dave Ribiero was needing them for his stock-classer. Cometic IS expensive. Also, THE BEST.
Jim
Old 08-11-2014, 08:22 PM
I have a lot of OEM gaskets I'll look and see if I have any 326 head gaskets. It won't be until Friday though. If I have any you can have them for the cost of the shipping.
