In order to get into my '64 I have to reach inside and pull the door handle up in order to open the door. The push button on the outside seems jammed. (used to work fine) I'm not sure where to start so I think I might take off the interior panels and see if I can get to the inner workings. Any help / advice would be appreciated. Thanks in advance.
Follow up; took off the inside door panel (window crank, door handle, armrest) got to the inner workings up near the top/inside - shot with some white lithium grease, also took off the outside door handle and applied some axle grease to the square contact plate, put it all back together ...works now, smooth as butter
