Old 08-24-2014, 01:54 PM
67SS&99SS 67SS&99SS is offline
Default window channel needed for 62 tempest
Hey everyone, been a while since I've posted but I need help finding a part. I rolled the window down in the tempest a few weeks ago and the glass separated from the channel. I was able to roll it up until I had time to disassemble the door to see what the problem was. When I got it apart the steel channel that holds the door glass was rusted so bad that part of it was gone and the other part was bent. This is for the drivers door on a 2 door coupe. Do any of you know where I could get one? Anybody have a used one they would sell?
I found this on steel rubber products website but I think this is just the upper portion. http://www.steelerubber.com/steel-sa...nel-50-0418-59 I guess I would have to rivet or weld the roller guide to the bottom of it?
Thanks,
Andy
Andy
1962 Tempest Lemans 4 cyl auto
1967 Camaro
1969 C/10
1969 D300
1972 K/5
1974 'Cuda
2005 2500HD Duramax
Old 08-24-2014, 04:26 PM
azkeebler's Avatar
azkeebler azkeebler is offline
What you found from Steele is what I used for both my cars. You will need to weld, or rivet the roller channel and guides to it, but is easy. The most difficult part is setting the glass in with butyl tape. My glass guy made a mess of it, more likely could have done it myself and saved $50.
2-1962 Lemans convertibles 4cyl, auto
1962 Tempest safari wagon (running project)
1972 455 Formula (tribute)
1962 Skylark convertible 215 4-barrel , auto
2009 G8 Sport red metallic, Onyx leather
Whatever else that make my way into the driveway
Old 08-29-2014, 09:31 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
Steele is the part. Weld or rivet. Use black rtv or windshield sealant. Fill channel, insert window, trim excess. Works great on wind wings. Don't use tape anymore.
Old 08-30-2014, 11:24 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Rusted lower glass channels is a real problem on 62 and 63 Lemans cars, especially convertibles. I had to repair/restore both sides on my car. People are right the part that steele sells is just the "U" shaped channel that the lower edge of the glass rests into. The other part is a C shaped guide for the regulator rollers. When GM made these parts; after spot welding (which is the way the upper and lower sections were originally joined together) they chrome plated the entire assembly. This was because when you roll the side glass all the way up, the top thin edge of the glass channel is ever so slightly visible both from inside and outside the car.
Peter Serio
Owner, Precision Pontiac
Old 09-21-2014, 03:21 PM
ronk455's Avatar
ronk455 ronk455 is offline
Is this the piece you are looking for? I found this today when cleaning out the garage. I have sold my 62, so I won't be needing it. $20.00 plus shipping if interested.
Ron
