Old 08-24-2014, 04:15 PM
Jim Pennell Jim Pennell is offline
Default '61-'62 Tempest air cleaner assembly
I'm in need of a correct air cleaner assembly, base and cover, for my '62 4 cyl., 4 barrel carb. Tempest.
Thanks.
Jim
Old 08-25-2014, 10:18 AM
BOB VIDAN BOB VIDAN is offline
Jim, i have a few air cleaners that I'm not sure go to what. Is there a picture of what you're looking for somewhere so I can check for you?
Practicing social distancing for 65+ years
Old 08-26-2014, 07:21 AM
trynsave trynsave is offline
i sent u a pm-did u get it?
Old 11-07-2014, 09:01 PM
gregneun gregneun is offline
Default air cleaner
4 barrel, 4 cylinder. Is this what you need? Removed from a 1962 Tempest.
Greg
Old 11-08-2014, 07:17 AM
how much?
Old 11-09-2014, 01:20 PM
Default off to ebay
$54.99 opening bid.
http://www.ebay.com/itm/291291172730...84.m1555.l2649
Greg
Old 11-12-2014, 09:10 PM
GaryK's Avatar
GaryK GaryK is offline
Greg,
what is with all the holes drilled into the base of the air cleaner?
Gary
Old 11-12-2014, 11:22 PM
Default holes in the air cleaner
I assume that the holes are factory stamped. There are 2 holes in the side where the bracket bolts go into. The holes, on the base, are to uniform to be drilled.
Hopefully someone with more knowledge than will chime in here. I don't have one of these cars.
Thanks,
Greg
Old 11-13-2014, 06:45 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default air cleaner holes
I have a 63 Tempest wagon with a transplanted 326ci 4 barrel engine. The air cleaner assembly is like yours....it has holes in the lower plate. I thought someone must have got happy with a hole bit in a drill. Since seeing your air cleaner, it seems the factory may have stamped the holes.
Old 11-13-2014, 08:48 PM
GaryK's Avatar
Some of the holes are not centered and I would expect factory stamping be the same all around, that is why I questioned it. I asked a buddy of mine with a factory 4bbl set up on his 62 Lemans to check his air cleaner for the holes.
Gary
Old 11-14-2014, 08:15 AM
GaryK's Avatar
Gary
He said his has the same design with all the holes and he too wondered if it was done by the factory. It must be. Learn something new about these cars all the time.
Old 11-14-2014, 08:22 AM
the holes are centered-its an optical illusion (shadows can cause that)
