Old 08-26-2014, 08:32 PM
ta man ta man is offline
Default Timeslip
Timeslip from Aug 15..my car is on the left..bit of slippage in the 60 ft...a fellow board member Torquewar's on the right..both great street cars and driven to the track..my last pass I ran 11.59.
Old 08-26-2014, 08:36 PM
66bonne's Avatar
66bonne 66bonne is offline
Looks like you had some fun with your Poncho. Don't know your combo but that time looks very respectable.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 08-26-2014, 08:44 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Nice!
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 08-26-2014, 10:16 PM
mchell's Avatar
mchell mchell is offline
.. darn good considering the 60' ! what kind of weather were you running in??
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 08-27-2014, 05:24 AM
Here is the last timeslip..DA's ranged from 2274 early in the night to 1629 near 10pm..This is with a 3.08 gear and a 3900 lb car!
Old 08-27-2014, 08:00 PM
mchell's Avatar
nice.....what kind of tire were you running?...
Old 08-28-2014, 06:23 AM
Mickey Thompson ET Street 275/60/15...just CE 90/10 front CE 50/50 rear shocks nothing else for traction aids..
Old 08-28-2014, 06:29 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Nice runs. I love seeing these Pontiac street driven cars lay down runs like that with 3.08 gears and DOT tires!......Cliff
Old 08-28-2014, 07:09 AM
Thanks..even with a Holley it does ok....!
Old 08-28-2014, 08:22 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yep. Not too many Ferds and Chebbies at any track, on any day, that were driven there at 4000 pounds running 11.60`s. Course, most or none at any track would have had 3.08 gears. Even the big blocks would have had 3.73`s.
That`s the danger of Pontiacs on the street.
Old 08-28-2014, 09:39 AM
Gerrit's Avatar
Gerrit Gerrit is offline
That's good news since I'll switch from 26" to 28" DOT tires with my 3.08 geared bird.
26" just too small for me.
Old 08-28-2014, 10:17 AM
Cliff R's Avatar
A few years ago I switched from the 275/60-15's to the 255's, and they actually hook up better with more air in them than the bigger tires did. I am running them on stock 7" Pontiac Ralley wheels, which does favor the smaller tires as far as how much tread meeting the pavement on the starting line......Cliff
Old 08-28-2014, 08:08 PM
77 TRASHCAN's Avatar
That thing would run better with a Quadrajet on it....Sorry I couldn't resist, We always hear it the other way around...
What specific carb are you using???
Shut it off
Shut it off
Old 08-28-2014, 10:28 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Had a good time with TA man that night. Both cars were hooking good and i finally had a good string of 50s that night. The 47 run was really the icing on the cake.
I wanted to do couple more runs until i lost a alternator belt...`
Ernie and myself are always looking to hunt the other brands down with our street cars.
Going to head out tomorow night and see if i can get those numbers to improve.
TA man cant be there but we have our Pontiac day coming up ,something looking forward too.
Old 08-29-2014, 07:25 AM
grandville455's Avatar
grandville455 grandville455 is offline
Nice runs guys! Torque!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 08-29-2014, 08:19 AM
950hp Holley with a 50 cc pump on front....Torker 2 intake with a 1 inch open spacer.....
Old 08-30-2014, 01:37 AM
lust4speed's Avatar
What's the deal with listing E.T. at 594 foot? Haven't seen that before.
Mick Batson
Old 09-01-2014, 01:08 AM
hal101's Avatar
hal101 hal101 is offline
very nice that car is running great
hoping to make it to the track with my sons ta before winter last run was [email protected] with 2.56 gear
Old 09-01-2014, 01:44 AM
I believe that is where the beams start for the 1/8mile speed..if you do the math for the 594 and 660 split it works out to the mph for the 1/8th..
Old 09-01-2014, 01:46 AM
Low 12' with 2.56's!What is the combo?
