Old 09-04-2014, 01:29 PM
Scotty7185 Scotty7185 is offline
Default Master cylinder
Can I use a drum/disc master cylinder on a drum / drum car
Old 09-04-2014, 05:43 PM
No you can't the section that you hooked up to the disc portion would give to much fluid & pressure & cause the brakes to be out of balance which would cause one of the set of brakes to lock up harder then the other set .
Old 09-04-2014, 05:48 PM
David Jones's Avatar
Residual valve only for the rear and the amount of fluid pushed to the front would be issues I believe.
Old 09-04-2014, 05:52 PM
thanks guys
